Transmission clank
Old Sep 11, 2014 | 02:41 PM
F350Jay's Avatar
F350Jay
Transmission clank
I have an 2011 6.7 that has a h&s tuner. Lately my transmission seems to be confused about what gear it should be in when I'm driving about 45mph. It will sometime downshift hard. Has anyone else experienced this? I have a early build 2011 and heard that it could be a solenoid problem with the transmission. Thanks for the help
Old Sep 11, 2014 | 07:22 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Is it when your trans fluid is warm?
Mine occasionally does that when the transmission fluid isn't warm and I'm very light on the throttle. Its always done it with H&S's transmission tuning however.
Old Sep 11, 2014 | 08:13 PM
F350Jay's Avatar
F350Jay
It does do it then. It happens when I'm driving about 50mph in 6th gear and slowly ease out of the throttle. I called H&S and the told me to do an update on the software. I had also heard it could be a transmission solenoid.
Old Sep 11, 2014 | 08:32 PM
Dakster's Avatar
Dakster
Did you do the transmission solenoid tsb yet? Do you also have the delay to shift from Park to Drive or Reverse at times?
Old Sep 11, 2014 | 08:41 PM
F350Jay's Avatar
F350Jay
I've never noticed any delay. I have not gotten the solenoid replaced. Maybe if my dealer is tuner friendly I can get them to look at it. It doesn't do it all the tome
Old Sep 11, 2014 | 09:22 PM
Dakster's Avatar
Dakster
That was the problem with mine, it would be bad and then it was sense I was going to the dealer and it would quit doing it. Must be the same damn GPS sensor that knows when I am getting ready to pull into my driveway so it starts a regen.
Old Sep 12, 2014 | 09:40 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by F350Jay
I've never noticed any delay. I have not gotten the solenoid replaced. Maybe if my dealer is tuner friendly I can get them to look at it...
I would suggest having your dealership take a look, F350Jay. What's the current mileage on your truck?
Crystal
Old Sep 12, 2014 | 01:22 PM
F350Jay's Avatar
F350Jay
Crystal
Crystal,
My truck has 49,000 miles. Do you know the TSB?
Thanks
Old Sep 12, 2014 | 02:28 PM
frt2599's Avatar
frt2599
Crystal,
Thanks
TSB 11-7-10
07/07/11
6.7L WITH 6R140 TRANSMISSION - 2-3 SHIFT FLARE
AND/OR MIL ON WITH DTC P0733 AND/OR DELAYED
REVERSE ENGAGEMENT - BUILT ON OR BEFORE
4/11/2011
FORD:
2011 F-Super Duty
ISSUE
Some 2011 F-Super Duty vehicles equipped with 6.7L engines and 6R140 transmission may exhibit a 2-3 shift flare and/or malfunction indicator light (MIL) on with diagnostic trouble code (DTC) P0733 and/or delayed reverse engagement, with a build date on or before 4/11/2011. Symptoms may be more evident or seem worse after an extended soak.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Inspect vehicle build date.
a. If vehicle build date is on or before 11/19/2010, proceed to Step 2
b. If vehicle build date is between 11/20/2010 and 4/11/2011, solenoid replacement is not necessary, proceed to Step 3.
2. Replace the three (3) normally high solenoids [...]
steelhead2
Nov 25, 2013 07:41 PM
DadNSonF350
Jul 15, 2013 12:50 PM
young3675
1997 - 2003 F150
Dec 30, 2012 11:51 AM
timbuctooCal
S. California Chapter
Nov 2, 2011 09:57 AM
kb1aah
Mar 17, 2006 03:01 AM
