Wierd trans problem.
Old Nov 22, 2013 | 09:21 PM
steelhead2's Avatar
steelhead2
Heres my issue. Has a hesitation going into drive, or reverse. When its cold and i take off slowly and let off the throttle it almost feels like its going into neutral , then drive again. Also when i shifts into od at about 48-50 mph while lightly on the throttle it hesitates, then shifts. If im on it hard, or relatively aggressive it shifts perfect into od. Now, it doesnt do all this all of the time. The only thing thats persistant is the drive and reverse hesitation, and thats not all the time either. Another thing ive got is once in a while a dead throttle pedal. Ive got 5,000 on trans oil and filter change. I go no tow-haul flashing, and no check engine light on. I disconnected the batts thinking maybe the pcm will reset and straighten itself out. Or do i have trans solenoid issues?.
Old Nov 22, 2013 | 11:05 PM
Unrealo4's Avatar
Unrealo4
Mine did this really bad. Just started randomly one day plowing last year. It would somtimes hit pretty hard on the reverse shift. I only had about 15k on my fluid and filter's. Mark K mentioned a solinoid could of been partially plugged. I changed the fluid and filters again. And within 30 miles it was totally gone. Thats been over 8 months of daily towing and usage.
Old Nov 23, 2013 | 12:22 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Always try this before doing anything drastic.
Torqushift Shift Relearning Strategy TorqShift Harsh/Slipping Engagements, Upshifts, and/or Downshifts:
If these symptoms are experienced after the batteries have been disconnected, then it is due to the transmission adaptive strategy being cleared from the computer.
This may occur when the vehicle is delivered new from the factory as well.
1. Warm the engine and transmission to operating temperature with all accessories off.
2. Idle engine for one minute with engine warm and all accessories off.
3. Idle engine for one minute with A/C on.
Then:
1) While stopped, perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement.
2) While driving, perform three series of upshifts at light, medium and heavy throttle.
Josh
Old Nov 23, 2013 | 06:38 AM
dlibson's Avatar
dlibson
If it isn't a relearn issue, it could be a sticky or failing pressure control solenoid. I've also had a case with your symptoms that had a failing pump that would't hold pressure all the time. First start of the day took 5-6 seconds to engage into gear as the pump had to "prime" so to speak.
Start with the relearn procedure, then a fluid and filter change next. If that doesn't solve it, the next steps require some diagnostics.
Old Nov 23, 2013 | 06:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What fluid did you use? Your symptoms do sound like there may be some sticking solenoids.
Old Nov 23, 2013 | 11:43 AM
steelhead2's Avatar
steelhead2
I used mercon sp. actually, there shouldve been a 1 in front of the 5,000. Its got 15,000 on last change done on 6-11-11. It dont get driven much.
Old Nov 23, 2013 | 12:29 PM
steelhead2's Avatar
steelhead2
I did the relearn and when i went from n to r there was a hesitation, when i went from n to d it hesitated, shifted, back to n for a split second, then d engaged. Upshifts are excellent, maybe once hesitated going into od, but other than that it shifts great. Still had the hesitation going into r and d.
Old Nov 24, 2013 | 07:26 AM
steelhead2's Avatar
steelhead2
Is there a common reverse and drive solenoid?. Or is it one per gear?.when im rolling itll shift instantly from reverse to drive, or vise versa.
Old Nov 24, 2013 | 08:40 AM
Mark Kovalsky
Solenoid E is for the low/reverse clutch. That one may be your problem.
Old Nov 25, 2013 | 07:41 PM
steelhead2's Avatar
steelhead2
Ok, thanks for the time, and advice. Ill change it out and see what happens.
Kevin Escue
Apr 30, 2019 07:11 PM
Dcp2909
1997 - 2003 F150
Jul 31, 2018 03:39 PM
Mechanaut
Dec 27, 2017 09:22 PM
Carnes99
16
Feb 17, 2015 10:50 PM
F350Jay
6.7L Power Stroke Diesel
Sep 12, 2014 02:28 PM
