Sponsored by: Auxito
1997 Tranmission only has reverse
Old Dec 30, 2012 | 09:54 AM
young3675's Avatar
young3675
I have a 1997 Ford F150 4x4. I only have reverse gear, when you put into drive you have to rev up truck and then it will kick into gear & as long as you keep a little pressure on throttle it will stay in gear & shift fine if you let up on throttle it seems to go back into neutral & you have to start the the process all over. What is my problem? Please help. I have changed fluid & filter.
Old Dec 30, 2012 | 11:21 AM
JWC 3's Avatar
JWC 3
First off, Have you checked your fluid level . Be sure you ck it properly. Running in park . Did problem start before or after fluid change .
Old Dec 30, 2012 | 11:51 AM
projectSHO89's Avatar
projectSHO89
If the fluid level is correct, the transmission is probably worn out or busted internally.
Check manual 2nd gear and see if it engages properly.
Unklebob
Apr 2, 2015 11:49 AM
73 fourxfour
15
Feb 15, 2013 12:06 AM
timbuctooCal
S. California Chapter
Nov 2, 2011 09:57 AM
derekvmetzler
1997 - 2003 F150
Oct 19, 2006 11:23 AM
fordlogan
Oct 12, 2006 07:24 PM
