Sponsored by: Auxito
installing junk yard engine
Old Sep 11, 2014 | 08:13 AM
mcolabella's Avatar
mcolabella
found a5.4 engine add a local junk yard with 130,000 milesmy question is before I install the engine I was wondering if I should replace the spark plugs and what is the best procedure for doing suchand any other thoughts on preventive maintenance or other items I should consider replacing while the engine is out
Old Sep 11, 2014 | 09:04 AM
phoskins's Avatar
phoskins
First off, I've never done this, so my advice is basic at best.
1. Is the engine going into a vehicle that had the 5.4 previously? Is the engine from the same year as the vehicle it's going into? You could be in for a lot of
2. While the engine is out, I would replace the following if at all possible: Gaskets (intake, valve cover, oil pan, exhaust manifold, especially if there's any evidence of leaks, belts, hoses, spark plugs, spark plug wires, engine oil & filter (USE HIGH QUALITY ON 5.4's!!).
3. Check/replace cam phasers and related parts. I only know this from reading threads on FTE. I have no further knowledge, but these are important.
It will be SO much easier to do the gaskets and whatnot with the engine OUT. There is never a better time to do so!!!!
I'm sure others will chime in with their opinions/advice, and most of them probably have more experience with this than I do.
Best of luck!
Old Sep 11, 2014 | 09:13 AM
mcolabella's Avatar
mcolabella
Mine is a 97 5.4 and the donor is a 98.
Planning on
belts
water pump
fluids
Not sure what to do about plugs though any other engine it would be a a no brainer
Old Sep 11, 2014 | 04:39 PM
skidmarks82's Avatar
skidmarks82
How much did the motor run $$$
Old Sep 11, 2014 | 07:31 PM
Dr. Dirt's Avatar
Dr. Dirt
no cam phasers on this one. it's a 2 valve not a 3. no variable cam timing.
sounds like you're in the right direction. plugs, boots or wires, gaskets, water pump, oil and filter of course, belts, hoses.
good luck
Old Sep 12, 2014 | 08:54 AM
F150Dad's Avatar
F150Dad
This maybe overkill, but I would SERIOUSLY consider Head Gaskets. After reading here for the past year or so, it's not a matter of IF on a 2V Head Gaskets, but WHEN. The 2V's are notorious for failure at or around 125,000 to 155,000. Went through it with mine (son's). They lifted the cab off the frame to do the job, about $2,500+. If you have the funds to do it, I would. Gaskets aren't that expensive, and if doing other gaskets (as mentioned above), just buy the entire gasket set as head gaskets should be part of the set. Also they are the latest and greatest design/materials. You will also need "New" head bolts (buy from Ford, will most likely have to be ordered). Just my opinion.
Old Sep 12, 2014 | 09:39 AM
mcolabella's Avatar
mcolabella
I paid 350.00 for the engine I will look into the head gasket replacement
Old Sep 13, 2014 | 07:22 PM
skidmarks82
$2,500+ is $1,500 too much , I was quoted $1,000. Right About head gasket , well plus new studs . My new motor from powertrainproduct.net was only $2,500 did it myself . Easy just time consuming . Pull out radiator, u have a couple inches of space to pullout n from here it's just removing n remembering along with torque specs. Xoxo! does that $350 have 350,000 miles?
Old Sep 14, 2014 | 03:05 PM
galaxie641's Avatar
galaxie641
When I did mine I did water pump and plugs, no reason not to do them when it is so easy to access all 8. Think I also did belt tensioner and idler pulley(s).
Old Sep 16, 2014 | 12:19 PM
BFTUFF's Avatar
BFTUFF
I'm doing the same thing but with a but with a newer more powerful version non-PI to PI. I would include front crank seal, rear crankshaft seal, and new valve seals. You may also need a new EGR tube to the exhaust manifold if the bottom nut adapter breaks/corrodes off inside it.
Old Oct 6, 2014 | 09:09 PM
CHOPTASTIC93's Avatar
CHOPTASTIC93
im doing an engine replacement on my 02 5.4, with the engine out of a somewhat junked 98, and from experience i can tell you your best bets for replacement will be to take the time and do it right, replace the plugs and COP's, while the engine is out, (it would be wise at this point to have a timesert kit with extra inserts) go ahead and rethread all your plugs, just to avoid having to time sert them later if and when they blow out, also change your exhaust manifold gaskets, intake gasket, valve cover gaskets, and serpentine belt if necessary, as well as oil pan and gasket, be careful in taking out and inserting the engines that you dont destroy the flywheel teeth or torque converter for your transmission, speaking from experience (thank you to the donor truck for the trial and error) when you are ready to lift the engine out, lift and place a stand with a small sheet of wood to disseminate the pressure from the weight of the truck, so that you dont destroy the bell housing on your tranny,( the donor truck ended up with the jack stand starting to push through the bell housing) you want to have it lifted and at more or less the same angle that the engine is coming out or going in at so as not to destroy anything. a hoist with an extendable boom is ideal, as well as an engine balancer to go with it, and a stand for the engine to sit on while you clean and prep with all the new gear is an absolute life saver. best of luck to you and hope all goes well, mine should be up and running within the week and hopefully yours goes just as fast
Old Oct 6, 2014 | 09:35 PM
BFTUFF's Avatar
BFTUFF
I've got all the seals and gaskets. I have been on-the-fense about installing "Timecerts" preemptively. I know it would be much much easier to do while out, but will then have to buy new head gaskets. Jbrew advised to just install as is with new gaskets and torquing the plugs to 28FT lbs as per the Ford TSB. I've never had a plug blow out on my still running 98' 5.4L. The last time I installed plugs I hand tightened them solidly per years of experience with aluminum head of all kinds. I know, I sure wouldn't want to have a plug blow out after all that swapping work and money spent. I may call the machine shop and see what they get $ to install new ones.
Old Oct 6, 2014 | 09:41 PM
CHOPTASTIC93
you shouldn't have to replace your head gaskets just to do time serts.
Old Oct 7, 2014 | 02:24 PM
GuyGene's Avatar
GuyGene
I'd do all the above, but don't know about the timeserts, if the old plug threads look good and come out okay. All hoses, belts, gaskets, etc.
Hmmm, got me to thinking - my '02 is so clean and new looking, wonder if I could put a new 5.0 and six speed in her?? Oh well, always dreaming...
Old Oct 7, 2014 | 05:09 PM
BFTUFF's Avatar
BFTUFF
If you don't like the idea of leaving aluminum filings in your combustion chamber, you should remove the heads while the engine is out and install the "Timecerts" correctly. Ask any machine shop. Using grease or a mini vacuum to remove the chips is foolhardy. Chips will remain and very possibly ruin your newly installed engine.
Floorking69
Jun 23, 2017 05:32 AM
fishheadford
Jul 13, 2015 07:13 AM
thebigk
1997 - 2003 F150
Jan 11, 2013 09:07 AM
r0858
1997 - 2003 F150
Dec 3, 2009 08:47 PM
Mike12pt
13
Feb 21, 2006 06:47 PM
