Sponsored by: Auxito
engine replacement
Old Jan 9, 2013 | 12:06 PM
thebigk's Avatar
thebigk
engine replacement
Sorry if this question is already answered on here somewhere but I couldn't find it. My truck is getting way up there in miles, 180,000. I'm looking at buying a rebuilt engine and just swapping them. If I buy the same 5.4 2valve from the same year (2001) is there anything special that needs to be done to get it to run? Will the PCM know that the engine is different and stop it from running or can I just drop the new engine in and hook it up? Thanks for any advice.
Old Jan 9, 2013 | 06:52 PM
Bluegrass 7's Avatar
Bluegrass 7
First, if your engine is still good, don't repalce it just for the mileage.
Mine is at 184,000 and will be going for 225 to 250,000, then it's another truck not an engine, after 12 years.
Same year motor just replaces the old one.
The computer does not know the difference.
Good luck.
Old Jan 9, 2013 | 11:45 PM
thebigk's Avatar
thebigk
Thanks for the info. I plan on keeping the truck until it rusts away and right now it has no rust so that will be a while. I just don't want to get caught without it at some point because of an engine problem. I haven't really heard great things about these engines. Seems the 2 valve engine doesn't have problems with the spark plug breaking but sometimes removes spark plugs on it's own. Guess they all have their own problems.
Old Jan 10, 2013 | 01:52 PM
Bluegrass 7
The plug blowout issue was mainly the 5.4 up to 2001.
After 2004 and the advent of the redesigned head to allow for camshaft control and 3 valves, different plugs were used that resulted in a problem when plugs left in place to long.
Normally not a good thing but ***** happens now and then until it's corrected.
Good luck.
Old Jan 10, 2013 | 02:18 PM
frankg3079's Avatar
frankg3079
I was wondering if there is a build date that the blow out problem was corrected after. I just bought a 2001. Don't know if any plugs have been changed or holes repaired. Runs fine right now. Just wondering if this is an issue I may have to deal with.
FrankG3079
Old Jan 11, 2013 | 09:07 AM
Tex1986's Avatar
Tex1986
My truck has 256 on the clock and runs great. As long as you keep your oil changed 5k, every , your fluids checked, follow manufacturers scheduled maintenance, flush your trans every 50k... you'll be ok. The main factor I've seen in vehicle failures is lack of maintenance. Be rigorous and vigorous about maintenance and the vehicle will last you a long time.
mcolabella
1997 - 2003 F150
Oct 7, 2014 05:09 PM
Mcrafty1
Modular V8 (4.6L, 5.4L)
19
Oct 5, 2014 04:06 PM
Denola
Jan 2, 2013 06:22 PM
BigDiesel2011
1997 - 2003 F150
May 19, 2011 11:24 AM
r0858
1997 - 2003 F150
Dec 3, 2009 08:47 PM
