Engine RPM
Old Sep 10, 2014 | 04:54 PM
f350project's Avatar
f350project
Engine RPM
What is ideal engine RPM while cranking to get the motor started? While cranking I won't get over 200 RPM. The engine sputters and puffs smoke but fails to light. Absolutely everything else required for a start has been attained ie: ICP pressure 800+pis ICPv .28 IPR% 49 FICM sync yes, CKP/CAM sync yes, Exhaust back pressure is good. FICM V12 L12 M48 (from dieseltechron)
Injectors/PCM passes all test KOEO no faults whats DTC what so ever. Batteries are good and alternator is brand new. Batts put on trickle charge over night.
I have used all the awesome info from this forum to eliminate all the usual suspects and have read that the engine RPM need to be around 250. I may get 160-180 RPM and the starter is OEM not reman.
What do you all think.
Old Sep 10, 2014 | 08:43 PM
KDAVID1's Avatar
KDAVID1
Some lately have had issue with ac compressor being siezed preventing start.
Using IB AutoGroup
Old Sep 10, 2014 | 08:47 PM
bismic's Avatar
bismic
You should be able to start if it is 150 +
Old Sep 10, 2014 | 09:50 PM
78fordman's Avatar
78fordman
Do a bubble test.
Old Sep 10, 2014 | 10:28 PM
f350project
Test done
Originally Posted by 78fordman
Do a bubble test.
Injectors are new, I did a bubble test anyway and no bubbles from either bank
Old Sep 10, 2014 | 10:33 PM
f350project
Using IB AutoGroup
I'll check it out. Would it stop the engine from starting though it is spinning between 160-180rpm
Old Sep 11, 2014 | 01:14 AM
Yahiko's Avatar
Yahiko
Take the tension off the belt and see if you can turn the A/C compressor
by hand. If you can't then take the bolt out of the center of the A/C
compressor clutch and see if you can spin the pulley. It you can then
re-apply the tension to the belt and try starting it. You can run that
way if needed.
Sean
Old Sep 11, 2014 | 12:31 PM
f350project
A/C compressor is not the problem, I removed the belt and checked the pulley and it spins freely
Old Sep 11, 2014 | 03:20 PM
Zejokee's Avatar
Zejokee
Weak fuel pump?
Old Sep 11, 2014 | 03:23 PM
f350project
Originally Posted by Zejokee
Weak fuel pump?
Fuel pump is actually good. Didi blue spring upgrade and have a mechanical gauge attached to regulator. Puts out 62+ psi KOEO and during cranking
Old Sep 11, 2014 | 03:28 PM
Zejokee's Avatar
Zejokee
I had a truck like this the other day. Was working on it for a buddy. Truck wouldn't crank or anything. Starter was bad. Put a new starter in. It would crank and everything needed to start was achieved but it wouldn't start. I told the owner and he was like yeah it does that, hit it with some ether. I tried explaining to him it was a bad idea and waited till he arrived and let him do it. It fired right up. He says his truck will not start after sitting for a while, like weeks at a time, with out ether. I would not advised this at all. Just sharing my experience. I would think it would have to be something fuel related.
Old Sep 11, 2014 | 06:06 PM
Bonanza35's Avatar
Bonanza35
Like to know the answer to this as well?
Old Sep 11, 2014 | 06:37 PM
f350project
You and me both. I will be looking for a twisted fuel line tomorrow. Even though fuel comes out of the banjo when disconnected from the block it may still be restricted by some blockage
akmikek
Nov 4, 2017 03:45 PM
WatsonR
Jul 25, 2014 10:41 AM
missalot
Mar 2, 2007 11:07 AM
zirius
Sep 7, 2004 02:30 PM
