Timing chain replacement
Old Sep 9, 2014 | 08:56 AM
tbugher62's Avatar
tbugher62
Hi Guys,How hard is it to replace a timing chain on a 1994 Ford F 350 with a 460 motor ?
Old Sep 9, 2014 | 10:36 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
In comparison to what?
"How hard" doesn't tell me anything about your abilities/experience, tools and work space.
Consider... you have to remove the radiator, entire front dress, harmonic balancer, water pump, timing case and anything else in the way.
Typically on a vehicle this old there is a lot of scraping and cleaning of parts and gasket surfaces.
You may want to go back with a new water pump and backing plate.
You may need to sleeve the balancer or install a new one so the FMS has a clean surface to ride on
Good time to install a fresh belt and tensioner.
You'll definitely want to thoroughly clean the engine before opening it up.
Be careful when scraping the front of the block that you don't drop a bunch of stuff in the oil pan.
niko20
Mar 16, 2018 06:49 PM
66v8baby
Nov 5, 2016 06:36 AM
DBGrif91
Sep 15, 2013 12:55 PM
kids_ride
1983 - 2012 Ranger & B-Series
Feb 10, 2008 11:31 AM
lmadore
Aug 8, 2005 01:28 PM
