1991 2.3 5 speed issues
Old Sep 8, 2014 | 02:04 PM
lonestar729's Avatar
lonestar729
Okay heres my list of issues
At idle will stall out, its almoat as if i shut the key off, or sometimes takin off itll sputter and stall, fuel filter has been changed.
Back part of the tranny housing leaks, is there a gasket for that?
Old Sep 9, 2014 | 07:20 AM
pawpaw's Avatar
pawpaw
Pull the vacuum line to the fuel rail mounted fuel pressure regulator to see if its wet inside with fuel. If it is, the regulators diaphragm is leaking & the fpr needs to be replaced.
If that looks ok, perform KOEO, KOER & leak down fuel pressure tests at the fuel rail Schrader valve test port & let us know how it goes.
Old Sep 9, 2014 | 09:11 AM
f5fordgirl's Avatar
f5fordgirl
The trans may be leaking from the 3 small rubber plugs on the back side of the shifter cover. Clean the trans good and keep watching for the leak, you don't want that trans to get low on oil.
Old Sep 9, 2014 | 12:26 PM
lonestar729
Alright thanks, ill check after work and keep yall postes
Hotwheelbill
Mar 6, 2014 08:27 AM
BrendanT7
Dec 21, 2012 11:33 AM
Schlominator
Feb 26, 2011 08:39 PM
97F250LD4X
Modular V8 (4.6L, 5.4L)
May 30, 2010 08:52 PM
PolarBearKing
28
Feb 19, 2008 11:04 PM
