Skyjacker spring orientation?
Old Sep 6, 2014 | 05:31 PM
NW 150's Avatar
NW 150
I just picked up my front/rear leaf spring packs today for my 78 F250. Now the rear spring packs are obvious as to their install orientation, but I cannot figured out which way the front springs would go? Measurements on the front springs from both eyelets to the center pin are approx. 27.5" and 26". Other than that I haven't seen anything to deciphers which way they are to be installed.
Old Sep 6, 2014 | 06:09 PM
fordrealdrive's Avatar
fordrealdrive
Check inside diameter of the eyelets where the bushings go. I can't remember if their the same or not...anyway, the bushing for the larger bolt goes to the front.
73 -early77 F250's "highboys" used 9/16" bolts front and rear.
77.5/79 used 5/8" in the front and 9/16" in the back eyelet.
Old Sep 6, 2014 | 06:12 PM
NW 150's Avatar
NW 150
The front springs don't have the bushings installed and the eyelets are the same on both ends (spring not the bushings). I have the bushings but they came in a separate hardware kit. The only thing I can set apart are the lengths to the center pin. If you could check yours that'd be great!
Old Sep 6, 2014 | 06:23 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
The longer end should go to the back.
-Junior
Old Sep 6, 2014 | 06:32 PM
lafermedavid's Avatar
lafermedavid
ATS you guys rock! Hooked me up with everything I needed
Old Sep 6, 2014 | 06:33 PM
fordrealdrive
Yep, longer end towards the rear.
Old Sep 6, 2014 | 06:37 PM
NW 150's Avatar
NW 150
Cool thanks!!
Old Sep 6, 2014 | 08:44 PM
NBC-Steve's Avatar
NBC-Steve
I stand corrected from my last PM to you. (My bad, I'll treat you to a beer if you are ever in my neck of the woods. ) I measured my springs and it's 28" in the rear and 26.5" in the front.
helm40
Oct 8, 2018 10:09 PM
Mach1394
Aug 24, 2015 08:51 AM
Pickupmanx2
Aug 11, 2014 01:04 AM
95_460
Feb 5, 2011 02:19 PM
spinella
Mar 3, 2010 08:49 PM
