Temperature Gauge
Old Sep 5, 2014 | 01:19 PM
78fordguy's Avatar
78fordguy
Temperature Gauge
78 f250 351m I replaced the coolant temperature sensor and when I turned the key on the gauge pegs to H and stays there. Could this be a faulty dash cluster voltage regulator? My cluster has idiot lights with a temp and gas gauge. Gas gauge only moves up a little right before "E". My coolant gauge didnt work before I changed the sensor. I know this gauge isnt accurate but wanted it working anyways. Winter is around the corner and I want to put a higher temp thermostat in. But I want to see how the temperature is before I put the new thermostat in.
Old Sep 5, 2014 | 01:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Pull the wire off the temp sender and turn the ignition to "run" position. What does the gauge do? If the needle doesn't move then the sender is bad. If it still swings all the way over to "H" then check for a short in the wiring between the gauge and the sender.
Anthony Bauwens
Nov 8, 2016 08:39 AM
fordbyfifes
May 4, 2016 10:56 AM
tommyl
Feb 22, 2012 08:09 PM
sfc11b
Apr 16, 2005 10:19 PM
fim
Aug 24, 2000 02:50 PM
