300 break in process
Old Sep 3, 2014 | 06:01 PM
Dr. Dirt's Avatar
Dr. Dirt
we just got done with a rebuild on the 300 in our 79 F100. I bought the royal purple break in oil from o'reilly. I put it in and the truck starts and runs good, but I would like to know the break in process to do it correctly. the only bad thing is I don't have a tachometer on this truck. would there be any other way to do this?
Old Sep 3, 2014 | 06:06 PM
JWC 3's Avatar
JWC 3
Get a cheep tach and run at 1500 -2000 rpm for ten min. to break in the cam .
Old Sep 3, 2014 | 06:22 PM
fmc400's Avatar
fmc400
MSEE
A tachometer is much cheaper than a ruined brand-new engine, right?
Old Sep 3, 2014 | 06:49 PM
HIO Silver's Avatar
HIO Silver
A Sun SuperTach III is $45 from Autozone.
Old Sep 3, 2014 | 07:03 PM
78fordguy's Avatar
78fordguy
Ive had 2 of the sunpro 3 tachs and ive had issues with both on different trucks. They seemed to only work when they wanted to and at times read 0 rpm on a 95 as well as a 78 pickup. My friend had one in his pulling truck and same issue. Not sure if a bad batch or not. We got them at the local autozone.
Old Sep 3, 2014 | 09:25 PM
Blue and White's Avatar
Blue and White
Last break-in I did was "tachless". You want 2000+ RPM for 20+ minutes for the cam/lifters. 2000 RPM is more than a fast idle but not revved crazy high. I judged by ear and varied a bit. It worked. Getting the timing and mixture in the ball park along with a good fan in front of the radiator helps a lot in avoiding overheating. After the cam break-in, it needs some load to seat the rings. Adjust timing and mixture as needed then drive it, step on it but not continuously for a while and enjoy it.
A "known good" carb on break-in helps a lot in getting the mixture close.
Old Sep 3, 2014 | 10:58 PM
Dr. Dirt's Avatar
Dr. Dirt
true story. I guess it's time to invest in a tach.
Old Sep 3, 2014 | 11:30 PM
co425's Avatar
co425
As stated above get a tach. Break in that cam at 1500 to 2000 rpm for 15 to 20 min. After she cools down change the oil. Make sure you add some zddp as well.
Old Sep 3, 2014 | 11:49 PM
F-250 restorer's Avatar
F-250 restorer
Yes, you have to use the zinc additive. Try the inline forum too.
Old Sep 4, 2014 | 08:09 PM
Dr. Dirt's Avatar
Dr. Dirt
We bought the royal purple break in oil that has the zinc in it, will this be okay?
Old Sep 5, 2014 | 08:44 AM
co425's Avatar
co425
As long as it brings the zddp to an acceptable ppm you should be good. From what I understand including your base oil, 2000 parts per million is a good number to be at.
Old Sep 5, 2014 | 09:36 AM
F-250 restorer
You should be fine. Some cam mfg's like you to use an oil additive for normal use. Check with them and see if you should use one. Good luck. BTW, there is an inline forum here.
Old Sep 5, 2014 | 02:19 PM
Dr. Dirt's Avatar
Dr. Dirt
thank you. I'll post it in there and see what I come up with
gordo350
Jul 17, 2004 09:59 AM
Rocky Ranger
17
Mar 26, 2004 10:31 PM
ewellman
Aug 2, 2003 10:49 PM
rayvin_
Jul 18, 2002 11:09 AM
TallPaul
Apr 25, 2000 05:17 AM
