Snow Blowers
Old Aug 31, 2014 | 08:44 PM
ford2go's Avatar
ford2go
Snow Blowers
Hi,
I'm looking for a good snow blower. I have around a 250 foot gravel driveway and just a small sidewalk.
I have managed with an 8 hp from Sears for several years, but my neighbor often plows it out with his big ATV.
But, he will be spending more of the winter in Nevada, so he won't be around.
I would just as soon have somebody do it, but they keep quitting after they find out how hard it is on their trucks.
Cost is always an object, but I want something capable and reliable.
Any thoughts?
Thanks,
hj
Old Aug 31, 2014 | 09:46 PM
Ford_Six's Avatar
Ford_Six
Heavy snows are good with a snowblower, but a light snow can take much longer with a blower than with a plow, so depending on where you are it may be better to plow it.
I have an older 46" Craftsman blower that was mounted on my GT6000, but then the tractor died so now it's getting reworked to use on my Yanmar. It was a decent unit in both powder and slushy stuff, except it didn't throw as far as it could. The impeller was pretty worn, so I added a strip of rubber to each blade to fill the gap to the housing, which should make it much better. This is a great upgrade to any snowblower, and can make a cheap one work like a high-end unit.
Old Aug 31, 2014 | 09:57 PM
donjamer's Avatar
donjamer
Originally Posted by ford2go
Hi,
Any thoughts?
Thanks,
hj
Being in Minnesota you probably get a lot of snow..
I would get a beater plow truck to do the job...
There are plenty of trucks out there in the 1,000 - 1,500 dollar range
Being its a gravel driveway it would be tough on a blower
Old Aug 31, 2014 | 10:39 PM
ford2go's Avatar
ford2go
Not really a good choice from my perspective --1500 for the truck + $ for the plow and hydraulics plus the misery of keeping it running. Not to mention that there's an art to good plowing.
My Sears does OK, but it needs a little more juice. It's especially an issue with the icy/slushy stuff. The gravel isn't an issue as long as I keep the skids adjusted right.
Thanks for the thoughts,
hj
Old Sep 1, 2014 | 09:09 AM
BIGKEN's Avatar
BIGKEN
I use a 27 year old Honda that I bought new...9 horse...24" cut. I can't imagine there's a finer machine out there. They are...however...very expensive. My neighbor has a newer Ariens...not 1/2 the machine my Honda is.
Old Sep 1, 2014 | 09:14 AM
slimbo13's Avatar
slimbo13
an old 2 stroke jacobsen what i use,,, spray silcone down the chute when wet does wonders
Old Sep 1, 2014 | 10:29 AM
old farm truck's Avatar
old farm truck
You can get a 45" walk behind for the driveway. Keep the little one for the sidewalks.
Old Sep 1, 2014 | 10:24 PM
ford2go's Avatar
ford2go
Thanks for the thoughts -- really like the first hand stories.
hj
Old Sep 2, 2014 | 01:54 PM
Bruker's Avatar
Bruker
Adding a piece of rubber to the end of the impeller as Ford_Six mentioned is a great way to get any snow blower to throw slush or powdery snow further.
Old Sep 2, 2014 | 10:18 PM
ford2go's Avatar
ford2go
OK - 2 tips for adding some rubber.
So maybe somebody can pretend pretend I'm stupid ( not really that hard ), and provide a reasonably simple method.
Thanks,
hj
Old Sep 3, 2014 | 05:49 AM
Bruker's Avatar
Bruker
Thanks,
hj
There are several YouTube video's of how people have done this. If you can get the impeller off the snow blower it will make it a bit easier. For the rubber donor I used some ~1/8" off of an old mudflap.
Aftrmidnite
Dec 21, 2009 10:53 AM
mark a.
21
Sep 28, 2008 05:01 AM
fyrhog
20
Mar 28, 2006 08:37 AM
radar_ridr
25
Oct 27, 2003 09:02 PM
christop43
17
Mar 20, 2002 07:35 PM
