I have a 04 Ex. with the 6.0. I drove to work just fine yesterday. I noticed no problems. It ran smooth. I get into my truck to leave work and get a long crank no start and P2614 is my only code. Would this code be the cause or effect of the no start?
so here is an update on my issues. I got my scanner on it and here are the numbers:
IPR% Key on engine off 14.7%
IPR% while cranking 47%
HPOP psi while cranking 1370 psi
FICM volts 47.5
battery resting voltage 12.5v
one thing that looked interesting is that key on engine off and while cranking the oil pressure on the dash cluster did not move from the resting position. The oil level is full
any ideas Please help.
could this be a fuel issue?
