Sponsored by: Auxito
Crank, but no start, HELP!
Old Jan 31, 2017 | 12:00 PM
dreamin_big42's Avatar
dreamin_big42
Exclamation Crank, but no start, HELP!
I drive a 2001 ford f150 lariat 5.4L. My truck will crank but not start, i am getting complete spark, and have ran a full fuel pressure procedure, and am getting complete fuel pressure, there is no water in my gas, everything checks out how it should. I ran a test on my cluster and it showed a code that said i am not getting connection to computer to start. I removed the cluster and repaired all loose wires properly, and it still wont start!
I have had many people look at it and they said it could still be a bad cluster.
Is there anything else it could be, or could i get clarification that is the problem? PLEASE HELP! Thanks!!
Old Jan 31, 2017 | 02:53 PM
enriched&beyound's Avatar
enriched&beyound
Please further/better explain how you got the "code"? and what code came up?
Are the fuses and relays for the fuel pump and ignition ok?
Does the anti theft light blink? slow? or rapidly?
Have you tried a different key?
Old Jan 31, 2017 | 05:13 PM
pdqford's Avatar
pdqford
While cranking, does the Check Engine Lamp remain on, or does it turn off?
Old Jan 31, 2017 | 06:31 PM
Bluegrass 7's Avatar
Bluegrass 7
Do the following, turn the key to run and let it set at least 1 minute.
If the Theft lamp flashes there will be a two digit code.
What is the code.
Taking the dash apart was not a wise move because you really don't know what's gong on yet and could have introduced more issues on top of what you started with.
Good luck..
Old Feb 1, 2017 | 05:49 AM
projectSHO89's Avatar
projectSHO89
Ah, hell! Just look at the flippin' THEFT light when you try and start the engine. If it's fast-flashing, PATS has shut off your fuel injectors due to a malfunction in reading the key.
Old Feb 1, 2017 | 08:04 AM
dreamin_big42
theft mode blinks regularly when truck is off, when i turn the key to the on position the theft symbol goes away, not sure what it did after i reinstalled the cluster.
Old Feb 1, 2017 | 03:21 PM
projectSHO89
You need to be sure of what it is doing at this time.
Old Feb 1, 2017 | 05:06 PM
70f100longbed's Avatar
70f100longbed
Does the odometer display the mileage or dashes?
Old Feb 2, 2017 | 09:41 AM
dreamin_big42
it displays the mileage
Old Feb 2, 2017 | 02:30 PM
pdqford's Avatar
pdqford
Old Feb 11, 2017 | 08:43 AM
Mickey Bitsko's Avatar
Mickey Bitsko
mine did the same, crank shaft sensor fixed it.
Old Feb 11, 2017 | 08:53 AM
projectSHO89
A crank sensor is one of MANY possibilities for a "crank, no start" condition.
There's a reason for troubleshooting, it's to prevent wasting time on wild goose chases, too often caused by simple reports of a single occurrence.
Old Feb 11, 2017 | 09:04 AM
Mickey Bitsko
im not SAYING that IS the op's problem ! I SAID , my crank sensor was bad and replaced it and now runs fine.
Loosin up your panties.
Old Feb 11, 2017 | 01:11 PM
projectSHO89
Well, congratulations on getting lucky in your guessing. Go buy a lottery ticket.
el-lobo
Sep 1, 2014 05:30 PM
mutang02
1997 - 2003 F150
17
Apr 6, 2013 10:13 PM
The Plow Guy
Mar 26, 2010 04:49 PM
ccoram
1997 - 2003 F150
Sep 26, 2005 05:01 PM
Colin94Supercab4.0
1983 - 2012 Ranger & B-Series
Jan 21, 2004 01:39 PM
