Cab Clearance Lights
Old Aug 30, 2014 | 09:52 AM
2015F350's Avatar
2015F350
Does anyone know if all New trucks come with the factory clearance light plug-in-connector and if so, where would it be located? The reason I ask, is I'm considering adding the cab clearance lights to my 15 F350. Really would like the factory lights but I hear Recon makes some similar.
Old Aug 30, 2014 | 10:17 AM
UGA33's Avatar
UGA33
The plug is under the driver side kick panel under the steering column. Stay away from the Recon kit. The Ford harness and lights go on so much smoother. I added them to my 2012. Little more work than the 2010 and older trucks but not bad. I have the wiring harness part number if you need it. There are a few to choose from.
Old Aug 30, 2014 | 10:25 AM
2015F350's Avatar
2015F350
Are the clearance lights the same for 2012-2015? Why stay away from Recon light kit?
Old Aug 30, 2014 | 10:32 AM
UGA33's Avatar
UGA33
The clearance lights are the same. The lights have been the same since '99. The harness I used should be the same you need since you have the Lariat Ultimate package. I installed a set on a truck, it was cut and splice vs plug and play. The hardware they sent to secure the lights were a joke requiring a trip to Home Depot and the placement of the screws on the light seemed to want to allow the back of the light to want to sit higher than the front. I can promise you that you will be happier using Ford hardware. I've done about 10 cab light installs for various friends and family. If they say they have a Recon kit, I tell them to find someone else to do it.
Old Aug 30, 2014 | 10:35 AM
2015F350's Avatar
2015F350
What is the light kit part number with plug-in connector
Old Aug 30, 2014 | 10:50 AM
UGA33's Avatar
UGA33
Harness: BC3Z-15A404-B
Lights (5): 8C3Z-15442-C
Old Aug 30, 2014 | 10:57 AM
2015F350's Avatar
2015F350
Thanks...I appreciate your help and advice.
Old Aug 31, 2014 | 10:54 PM
superdutyquest's Avatar
superdutyquest
Theres a guy on ebay selling the OEM kit for our trucks,Im going to buy from him because his kit includes a templet for the holes you have to drill so you cant screw up the roof of your fancy truck.
Old Sep 1, 2014 | 02:14 PM
2015F350's Avatar
2015F350
Cool let me know how it works out. Do you have his 411
Old Sep 1, 2014 | 02:23 PM
Dim Sum's Avatar
Dim Sum
This mod is on the docket for next month. Let us know who you order from and how the kit looks.
I want the Ford OEM kit as well.
Old Sep 1, 2014 | 02:48 PM
Dakster's Avatar
Dakster
I have the factory lights. What I want is just an LED replacement bulb. Kinda want to do that for all of the lights that automatically come one when you open the door or turn the key on. Try and take some of the electrical load off the batteries in the deep cold.
I keep finding the entire kit - not just the bulbs. I will keep looking though...
Old Sep 1, 2014 | 02:51 PM
MisterCMK's Avatar
MisterCMK
I ordered mine from superbrightleds.com
Sent from my Telegraph using IB AutoGroup
Old Sep 1, 2014 | 02:52 PM
Dim Sum's Avatar
Dim Sum
I just changed all of the interior lights this weekend. They sure do make a big difference between the old lights vs the new LEDs. Now I need to change the exterior bulbs.
Old Sep 1, 2014 | 02:54 PM
Dakster's Avatar
Dakster
What bulb did you buy for the interior? and what are you thinking about the exterior. I want a LED bar light in the front - but I also want a moose/bull bar which I should probably get first.
Main problem right now is $$ - I think the best bang for my buck are direct LED replacements at this point.
Old Sep 1, 2014 | 03:02 PM
MisterCMK's Avatar
MisterCMK
I didn't change any interior bulbs. Just the cab lights, cargo lights, 3rd brake, license plate and reverse lights
