!!!Before you watch the video, let me address that my spark issue is probably the cap and rotor. (They both look pretty old) But same rule applies, what if i replace both and still nothing?
A good place to begin:
(1)Red wire going into DSII should have 12V when ignition is on.
(2)White wire going into DSII should have 12V only when starting.
(3)Verify DSII module and distributor (both) should have a good ground
(4) as a test, run a jumper wire between both items to connect the ground between them
Good luck, ...jack
