Duraspark ?
Old Aug 3, 2007 | 04:02 PM
Woodsman_30350's Avatar
Woodsman_30350
Duraspark ?
Would a Duraspark distributor cap be considered an HEI type for ignition wire purposes?
Old Aug 3, 2007 | 05:47 PM
Franklin2's Avatar
Franklin2
If you want to call 8mm wire HEI type wire, then yes, the duraspark II takes the HEI wire. But HEI is a GM term if you want to get technical about it. The old points systems took 7mm wire.
Old Aug 3, 2007 | 08:51 PM
Woodsman_30350
Thanks Franklin. It is a Duraspark II and I plan on ordering the 8mm wire.
captntim
May 3, 2024 12:36 PM
68cabby
Nov 7, 2012 09:01 PM
aggiebronco
1978 - 1996 Big Bronco
Jun 30, 2003 08:01 PM
77sc
Electrical Systems/Wiring
Nov 12, 2002 12:47 PM
