Do you have the 6.0L trans cooler yet? That would be a better investment than a deeper pan, all that will do it hold more hot fluid, once it's up to temp it's up to temp no matter how much extra capacity it has. The pan itself will not actually cool the fluid no matter how many cool little circles or shapes it has stamped into it, only the plate cooler up front does.
Plan to run the 6.0 cooler that is next on the list with the guage, but saw this pan has cooling tubes in the bottom of the pan to help with cooling......
Not sure if it would do anything but add extra fluid, but with the tubes I thought it might help with the cooling some......and rust is not a big problem here in Texas......
