Sponsored by: Real Truck
2011 navigation system needed
Old Aug 25, 2014 | 06:39 PM
statement's Avatar
statement
Just putting together a 2011 350 with a 6.7. Purchased it as a non runnin repo. we rebuilt the motor due to dropped valves. put 2 new heads on and put my basket of parts back together. Got it done. Noticed the radio powered up but no volume. Finally after troubleshooting it for a while decided to remove it .thats when I found out that while it was at the dealership awaiting repo after being diagnosed with bad motor someone must have removed the factory nav unit and installed a xl or xlt CD player only one harness would plug in to power it the others don't fit. Does anyone know where there is a good deal to be had on a factory nav unit for a 2011 lariat 350. Thanks again
Old Aug 25, 2014 | 09:19 PM
Just Strokin's Avatar
Just Strokin
The radio that you removed must have come from another model year prior to 2011. I removed the radio from my 2011 XLT and put a Nav radio in it with no cable problems. It was plug and play after mounting a GPS antenna on the roof of truck. Both radios had two multi-pin plugs on back. The Nav radio did have a center connector for the camera connector if equiped.
A Ford Nav radio is going to cost you around $1800 on eBay.
Are you sure it came with Nav? Does it have the GPS antenna on the top driver's side of the roof?
Check the VIN here to see what it came with
https://www.etis.ford.com/home.do
Click Vehicle tab at top and enter VIN....the expand the build info on right side with the down arrow.
mikereidjr
Feb 24, 2019 01:38 AM
madsonp
Sep 11, 2012 02:03 AM
AndeyHall
Mar 29, 2011 11:24 PM
Fuzzys69
2004 - 2008 F150
Dec 30, 2010 10:03 PM
donmccarty
1997 - 2003 F150
Jul 24, 2003 06:43 AM
