Cab Mounts for a 1940 1 1/2 ton
I checked the link that christurney77 provided (https://www.ford-trucks.com/forums/92...ab-mounts.html) in response to timm1564’s post, V8 122 inch 1 ton (regarding the wooden cab mounts and found it very helpful. My question is, are the mounts the same for a pickup and a big truck? I'm getting ready to install the cab on my '40 1 1/2 ton and have no blocks to compare. If they are different, does anyone have dimensions or drawings of the proper mounts for a '40 big truck? Thanks in advance.
i,m not very internet savy. so i will post here, and you can move it were you want.now my dimensions are nowhere nice and neat like yours, but this is what i come up with today after supper. i will post it by its self ,so if you want to transfer it you won,t get all my rambling. now these are 70 some year old pieces of wood !
I think I've almost got it. Just not sure of the left side where it tapers upward. The end dimension is 1 9/16" but there appears to be a missing dimension to show how much the mount tapers upwards. There appears to be a dotted line which corresponds to the lower limit of the taper but I'm not sure of what the figure should be. Thanks.
https://www.ford-trucks.com/forums/9...-mounts-2.html
Give a look here, I think they are very similar.
you can see the difference here, the top one is one i made off your plan complit1107. and when i took the old supports out they were different
i don,t know why mine is different. i remember trying to fit the front supports and there was like (too floor tins meeting together with a 1/2 inch 90 degree bend on both)a floor board reinforcement. which didn,t line up ,with notch in wooden support. maybe a 2 ton has more reinforcement.this is the better of my 2 pictures theres more contrast on this one than the finish one ,which is all black.
