ICP sensor Interchangeable?
Old Aug 23, 2014 | 11:23 PM
jspreiss's Avatar
jspreiss
<hr style="color:#ffffff; background-color:#ffffff" size="1"> Hey experts, I've got a bit of a problem that I hope someone can answer. I'm in the middle of changing my ICP sensor on my 2003 6.0. I ordered the correct replacement part and now that I've got the truck apart i have found that "For Diesels" sent me the wrong part. I ordered part number 3C3Z9F838EA (ISK605 or ref# 1845274C92) which is specified for early '03 6.0. The packing slip indicates that part # and the plastic bag that was in the box also has that part #. Problem is, the sensor in the bag is actually part number 3C3Z9F838AA (ISK604, ref# 1845428C92) which is the sensor specified for 2004-2009 trucks.
Now here's the tricky part. On the page for the later model part ISK604 Ford Diesel Powerstroke ICP Sensors | ForDiesels.com
it states that an alternative part that can be used is Part Number: 1845274CP2 / 1845274 / 1845274C92 AP63407
that is, the early '03 can apparently be substituted on a later truck. However, the page for the earlier model ISK605 Ford Diesel Powerstroke ICP Sensors | ForDiesels.com does not list any alternative part. My question is, can the ICP sensor that is made for the later model be used in the pre 9/2003 engine? It seems logical to me that if the sensors are interchangeable for a later truck, they should work just fine on an early build truck as well. If not then it looks like I'll be sending this one back. The biggest difference I can see between the two is the size of the sensor body. The early '03 sensors have a 1 1/16" hex body and the later ones are a 15/16".
Anyone know if this sensor will work on my truck?
Thanks in advance.
Jason
Old Aug 24, 2014 | 12:31 AM
Yahiko's Avatar
Yahiko
Welcome to FTE jspreiss
Lets see if we can get a Mod to move this to
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
If you do a search I know that you will find a
thread on this subject. Some of the early 03 guys
will most likely let you know what is what with this.
Sean
Old Aug 24, 2014 | 06:23 AM
senix's Avatar
senix
moved to the 6.0 forum
Old Aug 24, 2014 | 06:39 AM
bismic's Avatar
bismic
Lotsa people doing it - no issues.
Old Aug 24, 2014 | 09:13 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Are you still testing the Early style ICP with your engine?
Josh
Old Aug 24, 2014 | 09:35 AM
catalinaflyer's Avatar
catalinaflyer
Running a late build ICP sensor in my early build 6.0 with absolutely no problems what so ever. Put it in, it will work just fine and may last longer do to a new design.
Old Aug 24, 2014 | 02:38 PM
bismic's Avatar
bismic
Josh
yes - still running quite well.
Old Aug 24, 2014 | 02:57 PM
Bullitt390's Avatar
Bullitt390
Notice any benefits? Higher HPO psi @ WOT or faster start-up?
Josh
Caroline Roy
Sep 8, 2015 07:15 AM
USMCveteran
Nov 18, 2013 12:22 AM
Restlesswildman
Nov 3, 2013 04:43 PM
MxRacer32
Feb 23, 2005 06:55 AM
