Erratic boost issues
Old Aug 23, 2014 | 11:15 PM
the_auto_tech's Avatar
the_auto_tech
So, as of a week or so ago I've noticed that the truck has been having an erratic boost issue. Sometimes when I go to get onto the freeway and have the truck under a good load it will build boost normally up to 20+ PSI but when I go to back down the throttle for cruising speed it drops down to 0 and stays there. If I get back on the throttle enough for it to downshift the boost comes back up and runs fun the rest of the drive. I've watched a scanner during the time and found that the VGT is at .85 when the boost is reading 0. MAP appears to be 14.9-40, EBP is 14.9-50, MAF is somewhere around 20-340 g/s. I was wondering if the turbo was sticking shut, but clearly the ECM is requesting it closed. Anything else I should check?
Old Aug 24, 2014 | 08:14 AM
78fordman's Avatar
78fordman
Watch ICP desired and actual ICP and make sure they match. Any codes stored?
Old Aug 24, 2014 | 08:18 AM
the_auto_tech
No codes at all in the PCM or FICM. ICP is dead on. 22% at idle with 580 PSI which has what it's read since it was bulletproofed. ICP actual vs desired is always within 10-20 PSI of each other. Was thinking about pulling the EBP sensor and tube and cleaning them to see if it makes a difference.
Old Aug 24, 2014 | 06:49 PM
MisterCMK's Avatar
MisterCMK
Turbo is sticking open. Mine is doing the same thing.
Old Aug 24, 2014 | 06:57 PM
78fordman's Avatar
78fordman
Isn't the vgt at 15% when the pcm is wanting more boost?
Old Aug 24, 2014 | 06:58 PM
MisterCMK's Avatar
MisterCMK
15% is commanding the veins open. 85% is commanding them closed
Old Aug 31, 2014 | 09:40 AM
the_auto_tech
That's what I was curious if mine was sticking. If the vanes are sticking open that would explain why it feels so laggy when it happens. I'm debating at this point if I want to pull the turbo and rebuild it with a billet wheel or if I just want to go to a Powermax.
Old Aug 31, 2014 | 09:51 AM
MisterCMK's Avatar
MisterCMK
I did nothing. Lol rodded on it a bit and it free'd up.
Sent from my Telegraph using IB AutoGroup
Old Aug 31, 2014 | 10:03 AM
the_auto_tech
Yea, mine is working fine now, but I know that it could use taking apart and cleaned. At that point I'm trying to decide if I want to take it apart and clean it and upgrade things with a billet wheel or if I want to go to a Powermax.
Old Aug 31, 2014 | 10:04 AM
MisterCMK's Avatar
MisterCMK
I probably should clean mine anyway. I still have to replace the up pipe gasket. The one that IPR sent burned up when a bolt loosened up. I'll pull the turbo to do that. Might as well clean it too.
Old Aug 31, 2014 | 12:31 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Pull it, clean it, rebuild it if you're so moved, and install a Riffraff Billet Wheel.
You can do it in a few hours and your truck will run awesome after that.
Old Aug 31, 2014 | 01:42 PM
merc82's Avatar
merc82
Turbo cleaning is quite therapeutic.
Old Aug 31, 2014 | 04:19 PM
MisterCMK's Avatar
MisterCMK
Come on over and clean mine!
Old Aug 31, 2014 | 10:08 PM
merc82's Avatar
merc82
Sure thing mang!!
Old Sep 1, 2014 | 12:16 AM
MisterCMK's Avatar
MisterCMK
Sure thing mang!!
Sweet! I'll have a new compressor wheel for you to put on when you clean it. Lol
Simon78
6.4L Power Stroke Diesel
Feb 29, 2016 05:47 PM
RmMillertime
Feb 22, 2016 03:32 PM
wannabe7.3
Feb 25, 2015 02:15 PM
MCR500
Jan 18, 2011 06:41 PM
chadjones99
Apr 7, 2006 10:16 AM
