PS question
Old Aug 20, 2014 | 01:44 PM
rews2's Avatar
rews2
PS question
So I got the power steering working good after gearbox replacement and a pesky leak. Last week out of the blue she steers like steering is manual it went from easy one handed turning to two handed overhand-underhand turning. Would a bad/worn out pump cause this?
Old Aug 20, 2014 | 02:37 PM
Freightrain's Avatar
Freightrain
Crack the line at the box and see if you have pressure(with engine running).
Old Aug 20, 2014 | 05:18 PM
jowilker's Avatar
jowilker
Should you find the fluid level good, try a no cost purge. Raise both front wheels off the ground and turn the steering wheel from sun rise to sunset and back 20 times. Lower it back and give it a power on test.
John
Old Sep 2, 2014 | 10:35 AM
rews2's Avatar
rews2
I may have found the problem on this. Over the weekend was doing the front brakes and checking the bearings etc.
While jacking up drivers side I saw a gap/space where the pivot bushing should be. I will be ordering for both sides to replace which is my question.
Can anyone offer up tips, tricks, advice or general input for this replacement? I haven't worked a beam front end before but have done coil springs and leaf springs.
mrjustice1324
Mar 27, 2019 08:49 PM
J C Hope
Apr 14, 2016 05:43 AM
WyoExplorer
Mar 12, 2010 05:40 PM
ddragon
1978 - 1996 Big Bronco
Apr 6, 2004 02:26 PM
bartspedden
Mar 5, 2004 08:20 PM
