limping home
Old Aug 27, 2014 | 10:57 PM
  #46
Yahiko's Avatar
Yahiko
Before I replaced the T-stat with a new OEM Ford
I was seeing a 8º~10º ∆ after I put the new one in
and the ECT was up to 192º vs the 182º. My delta dropped
down to about 4º~6º∆. The reason is I am un-sure of.
Also if you watch your temps as they start off from cold
and come to operating temps the ∆ can be all over the place.
Once it stabilizes then the ∆ also do.
But if I were getting ready to do an oil cooler do to ∆ readings
then a quick swap in of a known good OEM T-stat would be a
good first thing to try. $30 Vs $300~$500 or more if you have
someone do it and also on how much flushing you do.
Sean
2GSD
Aug 31, 2021 08:53 AM
ford150hunter
2004 - 2008 F150
Dec 5, 2011 04:34 PM
Big_E68
6.4L Power Stroke Diesel
Aug 18, 2011 05:21 AM
Blue Tear
1978 - 1996 Big Bronco
Aug 31, 2006 12:00 AM
greengeeker
1983 - 2012 Ranger & B-Series
Jul 26, 2005 08:51 PM
