E40d compatability
Old Aug 17, 2014 | 04:44 PM
westcoasting's Avatar
westcoasting
E40d compatability
Hey everyone, i am looking at a parts truck to use for a front end, engine core and whatever else i find. My truck is a 1996 F250 auto and the donor truck is a 1990 F350 auto.
Do these transmissions interchange from each truck or was there a lot of changes to them along the way? And if there were a lot of changes can i make the 1990 E40d as good as a newer one?
Old Aug 17, 2014 | 06:50 PM
Lead Head's Avatar
Lead Head
1990-1994 E4ODs are interchangeable. 95-97 are interchangeable. A 1990-94 can be rebuilt with 95-97 Internals, but must retain the 90-94 solenoid pack to work in a 1990-1994 truck.
Old Aug 17, 2014 | 08:22 PM
westcoasting
How much of the internals are different? This tranny was rebuilt a year or so ago so i was hoping to have it as a spare for my truck if i need one... probably best to sell it and recover the money i guess.
Old Aug 17, 2014 | 09:59 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Different bellhousings between diesel and gas. Also a unique bellhousing on the 460. Gas 4.9 through 5.8 are the same bellhousing, but watch the balance on the flexplate.
Also different tailshafts between 4X4 and 4X2
Old Aug 18, 2014 | 05:40 PM
Lead Head's Avatar
Lead Head
They're not terribly different inside, but the 95-97 improvements hugely enhance durability.
If the 90-94 transmission was rebuild last year by a good shop, it is very likely (extremely likely actually), that the 95-97 components were installed into it, since they supersede the earlier stuff.
A big giveaway is to look at the front pump on the transmission. There should be a code stamped into it that starts with "RF". An RF-F5 would be the updated '95 pump, if it says RF-F0, it still has the original 1990 pump in it.
Old Oct 15, 2017 | 08:56 PM
jdavey53's Avatar
jdavey53
I'm in kind of the same boat my 93 f250 tranny is done only has 1st an 2nd gear, can I interchange my tranny with a e40d out of a 97 e350 series? Both are automatics jus mine is a 460 big block an the e350 is a 5.4 triton.
Old Oct 15, 2017 | 09:06 PM
mrollings53's Avatar
mrollings53
No, the bell housings are different.
Old Dec 22, 2018 | 10:04 PM
Jackie Willis's Avatar
Jackie Willis
93 Bronco
Will an e4od from a 95 van with 5.8 work in my 93 Bronco with 5.8?
Old Dec 23, 2018 | 08:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is the Bronco a 4x4? If it is, then no, a van transmission will not work.
el-blanco
May 7, 2015 09:51 PM
QH rancher
Sep 18, 2010 05:15 PM
1just4don
Jul 14, 2007 09:49 AM
BGASTRK
Jul 7, 2004 07:19 AM
frederic
Mar 1, 2004 12:40 PM
