Rear leaf spring broke
Old Aug 16, 2014 | 07:29 PM
tobra's Avatar
tobra
4wd Low
77 f150 4x4. I broke the main leaf on my truck. My springs are 3in with 24 / 31.5 spacing. I can't find any at the wreckers. And don't have the money for new. I found a 77 f250 4x2. I looked online and they are 3in and the spacing is 24 / 31.5. The only difference I can see is the arc. Will the f250 leaf bolt up to my f150 shackles. Also if I remember correctly there is a pin on the axle that the leaf sits on. Will they bolt up to my axle.
Old Aug 16, 2014 | 09:31 PM
Blue and White's Avatar
Blue and White
Not 100% sure on the bolt up but probably. A close look and check of bolt diameters should confirm. Assume you will get both springs from the 250 if you do it so it sits even left to right.
Jacob2
Jun 1, 2019 01:51 PM
Joel Cassell
Apr 3, 2016 08:12 PM
HkyswiM
17
Aug 31, 2013 08:29 PM
FordOwnerJoey
Jun 21, 2012 06:18 AM
Aggie05
Bronco II
Jul 12, 2004 02:46 PM
