arm rest removal
Old Jul 12, 2003 | 11:34 AM
55-willys's Avatar
55-willys
arm rest removal
i have a 1990 f150 and want to remove the passengers side arm rest to make a repair to it. do i have to take off the door panel to remove it. i see theres a screw in the middle of the top, looking down. do i just take out this one screw and then pry it up, or are there screws holding it from the backside. thanks
Old Jul 12, 2003 | 01:12 PM
steve83's Avatar
steve83
arm rest removal
The screw you see helps hold the door panel on the door. You have to pull the door panel, and then the screws on the underside of the pad. Look it up here, and put "f150" in the Model field - not "f-150".
Old Jul 12, 2003 | 01:26 PM
Bubba Shrimp's Avatar
Bubba Shrimp
arm rest removal
I just replaced mine. I tried to get just the pad at the junk yard, but they sold me the whole thing. Still it was only $10.00 and I think Ford wanted about $70.00 for just the pad.
Steve is right on the money as usual. After you take the one philips screw out, unscrew the door lock button and take it off and then you can take something thin and put it between the panel and the door and pry the panel off. I think there are three fasteners on each side and three on the bottom. Work around the door slow and easy. These fasteners have been known to break, but you can get replacements for them cheap. After they are popped loose you have to slide the panel over the door handle. I found that if I pulled up on the handle it was easier to do this. Once you get the door panel off there are 5 screws holding the pad on You'll need a 7mm nut driver for those.
Old Jul 12, 2003 | 01:46 PM
55-willys's Avatar
55-willys
arm rest removal
thats what i figured. yeah, those bitchen plastic fastners. ill wait untill i feel like running down the fastners at the parts house. thanks for confirming my thoughts on how it comes off. couldnt be easy like my 75 chevy.
Old Jul 12, 2003 | 02:28 PM
Bubba Shrimp
arm rest removal
It's not really that bad. I've had mine off several times (had some electric window problems) and haven't broken a fastener yet.
t-rex_toyota
Jul 17, 2017 08:58 PM
jerryst
Nov 15, 2016 09:10 PM
72CC428
May 7, 2016 01:23 PM
jersdungeon
Aug 15, 2015 09:05 AM
bigblue
May 12, 2014 01:07 PM
