How to remove door panels 2014 F250 Super Duty
For a couple of weeks before I started my stereo install on my new 2014 F250 Crew Cab Super Duty, I was searching here for help on how to remove the door panels to replace speakers. Searching the internet, I found many diagrams and info for removing door panels on F150's, but not F250's. Sorry that I didn't take any pictures, but door panel removal is simple and as follows.
1. Remove the black sail panel at the front of the door by gently pulling and prying it off. There are two snap in retainers holding it in place.
2. Below the arm rest, there is a little access cover approx. .75" tall by 3" wide. Pry this panel off gently, and remove the two screws behind it.
3. Along the bottom of the door panel there are two screws. Remove these two screws.
4. Slowly lift entire panel up and off. Keep in mind that there are 3-4 electrical connectors still attached to switches. Disconnect connectors at this time.
IT"S THAT SIMPLE!!
IT"S THAT SIMPLE!!
