Sponsored by: Real Truck
LED lights..
Old Aug 15, 2014 | 10:45 PM
OklahomaDiesel's Avatar
OklahomaDiesel
LED lights..
Hello all. This is my first post. So be easy on me. Lol I have an 04 f250 with the 6.0. Absolutely love my truck. I'm trying to add some lights to the underneath of my doors that will come on when I open the door. And go off when I close it. I'm not sure where I should wire them into. Does anyone have some insight to this? Any and all help appreciated.
Old Aug 16, 2014 | 08:06 AM
acf6's Avatar
acf6
There may possibly be a connector under the cab on each side of the truck tucked up somewhere that are designed for the factory lighted steps...lights turn on when you open the doors. You could try looking for these connectors, should just be a small socket with 2 wires. No guarantees your truck has them though
Old Aug 16, 2014 | 10:08 AM
Trophy_23's Avatar
Trophy_23
IIRC, the wire you are looking for is black with blue stripe (dome light wire). Should be in the kick panel or under the plastic door sill.
Old Aug 16, 2014 | 10:59 AM
OklahomaDiesel
That's exactly what I needed to know. Thank you.
Old Aug 16, 2014 | 01:13 PM
hpwoee's Avatar
hpwoee
Where in Oklahoma are you?
Old Aug 16, 2014 | 01:15 PM
OklahomaDiesel
Im in francis. About 10 miles north of ada..
Old Aug 16, 2014 | 01:16 PM
OklahomaDiesel
And thanks for yalls help. Went out, found the wire. And they are all hooked up now. Only took me about 30 minutes. Ill post pics when it gets dark.
Old Aug 16, 2014 | 01:24 PM
hpwoee's Avatar
hpwoee
I live in okc.
Here is what my lights look like shining down on my running board. They are mounted on my rockers
Old Aug 16, 2014 | 01:35 PM
OklahomaDiesel
Very nice truck. I.mounted my under my rocker panels. I took my running boards of cause I like the way mine looks without them.
This is my girl before leds and before I took the running boardsfoff..
Old Aug 16, 2014 | 09:07 PM
hpwoee's Avatar
hpwoee
Nice truck!
Old Aug 17, 2014 | 06:21 AM
rjfetz1's Avatar
rjfetz1
Originally Posted by Bsipes30
I live in okc.
Looks nice!! Did you use the same type as on your air dam?? How many per side??
Old Aug 17, 2014 | 01:04 PM
hpwoee's Avatar
hpwoee
I used led light strips.
Amazon Amazon
Old Aug 31, 2014 | 09:13 AM
ketel0ne's Avatar
ketel0ne
bsipes30,
Was the connector under the trim on yours or under the truck?
These only light up when the doors are open/dome light is on correct?
WV is picky about white lights on the sides when running. So far I have amber under the doors but hooked into the running lights. Would be great to add white hooked into the dome light.
Old Aug 31, 2014 | 09:54 AM
hpwoee's Avatar
hpwoee
Mine was on the frame rail. Some have them some don't. I was lucky I suppose. They do come on with an open door but you will also turn them on if you use the button on the dash to turn on the some lights.
kefrko
Mar 16, 2015 06:45 PM
ZEALOUS_DRAGON
Electrical Systems/Wiring
Mar 19, 2012 10:21 PM
tg150
17
Jan 31, 2008 10:45 PM
schmidt64
Oct 26, 2007 01:44 AM
eysham
Jan 11, 2007 06:38 PM
