Interior Lights 2012 F350, adding step lights
Old Mar 13, 2012 | 11:08 AM
ZEALOUS_DRAGON's Avatar
ZEALOUS_DRAGON
Question Interior Lights 2012 F350, adding step lights
I have a 2012 F350 Crew Lariat. I am adding LED's under the side rails/steps/nerf bars. I want them to come on when the interior lights come on. I did this mod when I had my 2004 model. I need to know which wire in the door jam or somewhere else to splice into. Thanks
Old Mar 15, 2012 | 10:51 AM
78fourby4f250's Avatar
78fourby4f250
How about splicing into the push button switch that the door closes on? Then you can just run the wires down the door jam to your steps. Or you can splice into just about anything in the interior that comes on when the door is open, dome lights, lights in the door panel etc. That switch would probably be the easiest and closest place.
Old Mar 16, 2012 | 03:58 PM
Franklin2's Avatar
Franklin2
He has a new truck, they don't have door jamb pin switches, they have switches made into the latches. Also the new switches ground a wire, which goes to a body module, which senses this ground and sends the command over the trucks computer network. There is usually a interior lights relay in the fuse box.
The easiest way is going to be to intercept a wire going to a courtesy lamp. If you have a light on each side underneath the dash, I would tap into this and get this wire to the outside rocker area somehow. If you drill holes, I would drill a larger hole than needed, and use a piece of vacuum line over the wire to protect it where it goes through the sharp metal of the hole you drilled.
Old Mar 19, 2012 | 10:21 PM
ZEALOUS_DRAGON
Thumbs up Found It
Went ahead and probed till I found it. Its the grey wire with a purple stripe. Its also available in both door jams on both sides. These leds look great under the factory steps.
DrewF
6.7L Power Stroke Diesel
Jul 14, 2011 09:35 PM
tg150
Electrical Systems/Wiring
17
Jan 31, 2008 10:45 PM
tg150
Aftermarket Products
Jan 30, 2008 08:35 PM
Moyerboy
1997 - 2003 F150
Mar 17, 2007 10:37 AM
mybigredford
Dec 11, 2004 01:01 PM
