Ghost in the machine
Old Aug 15, 2014 | 12:10 PM
centurion2's Avatar
centurion2
Hello, my 99 f250 sd ABS light comes on and the A/C stops, when the ABS light goes off, A/C comes back on. Any clue as to what is happening?
Thanks
Old Aug 15, 2014 | 01:26 PM
projectSHO89's Avatar
projectSHO89
What does "the A/C stops" and "A/C comes back on" actually mean?
Old Aug 15, 2014 | 01:49 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Wild guess, but the answer will be in the GEM module. Scan it first, you need a fairly sophisticated scan tool to do this. Codes should point you in the right direction. Don't be too hasty and decide to replace the GEM module. It is model specific and requires programming particular to your VIN. That can get expensive in a hurry and still not fix the actual problem.
Old Aug 15, 2014 | 02:33 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sounds to me like a vacuum leak. Does the A/C REALLY stop or does it go to the defroster mode?
Old Aug 16, 2014 | 09:34 AM
centurion2's Avatar
centurion2
When the ABS light comes on, the Air Conditioner blower stops, when the light goes out the blower comes back on.
Old Aug 16, 2014 | 09:36 AM
centurion2's Avatar
centurion2
Thank you all for your input. I will try the scans first and go from there.
_Me2_
Mar 9, 2013 10:11 PM
boot2
Jun 26, 2012 05:33 PM
rick4115
Jan 23, 2012 02:46 PM
pick1967
Jan 13, 2011 07:38 PM
althund
1978 - 1996 Big Bronco
Mar 27, 2002 06:49 PM
