instrument cluster bezel
Old Aug 13, 2014 | 06:53 PM
Waco-kid's Avatar
Waco-kid
Quick question; On my 92 the black bezel around the instrument cluster has broken all but 2 clips due to the gravel road I live down not being graded. I looked on LMC they don't show to have ones specifically for the 92-93 diesel only the 94-96 diesel and 92-96 gas. So I'm at a crossroads on what to do. Will the powerstroke or gas ones adapt to the one for the idi or do I have to find an idi in the junk yard that's clean enough? Thanks for any info!
Old Aug 13, 2014 | 07:47 PM
*2fords*'s Avatar
*2fords*
Best I know, all the bezels are the same. You put your old switches whereever they were in your old bezel.
Old Aug 13, 2014 | 07:54 PM
mefast's Avatar
mefast
Going to a junkyard will be cheaper and better quality than buying from LMC. You should be able to get on for less than $20.
Old Aug 13, 2014 | 08:11 PM
Diesel_Brad's Avatar
Diesel_Brad
Junk yard or Ebay. LMC is JUNK
Old Aug 13, 2014 | 10:47 PM
Waco-kid's Avatar
Waco-kid
Alright thanks for the replies I'll check out the local junk yards for one.
Old Aug 14, 2014 | 06:58 AM
slinginsaws's Avatar
slinginsaws
GOOD LUCK I CANT FIND ANY AROUND HERE.
Old Aug 14, 2014 | 09:47 AM
ptut42's Avatar
ptut42
if you have all the peaces try plastic welding it all back together ive been messing around with it and seems to be really easy just use a cheap soldering iron and kinda stitch it together worked great on the plastic clips that hold the tailgate trim on just a thought good luck im about to try and fix the same peace your talking about
Old Aug 14, 2014 | 04:48 PM
Eddiec1564's Avatar
Eddiec1564
Good luck trying to find a 92 to 96 bezel, most are broken up even before the truck is at the yard..... 4 years and counting trying to find a good one...
Old Aug 14, 2014 | 07:41 PM
*2fords*'s Avatar
*2fords*
I bought one on Ebay with the fuel tank switch, head light switch and the trim pieces for around 20.00 + shipping.
Old Aug 14, 2014 | 08:03 PM
Evan_P's Avatar
Evan_P
Good luck doing that now. I sold the last clean one I had for a little over $200...
JTRH
Jun 23, 2017 02:13 AM
bduemig
May 29, 2014 10:53 AM
dlibson
Mar 7, 2010 10:28 PM
todd515
Oct 13, 2008 07:23 AM
paulpatter
Aug 17, 2006 04:25 PM
