instrument cluster converson
Old Oct 11, 2008 | 09:01 PM
todd515's Avatar
todd515
HI,
I was wondering how easy it would be to put a 99 to 2006 inst. cluster in a 1993 f-250 diesel. There was a bronco on e-bay that they converted to diesel and had the newer inst. cluster in there. the dash and the plastic still looked like the original set up and it looked pretty neat. Has anybody done this yet.
Thanks
Old Oct 12, 2008 | 09:31 AM
Conanski's Avatar
Conanski
No, you need a 92-93 cluster for that vehicle, nothing else will work right. If you put a cluster from another year in there you could have problems rangeing from instruments that don't work right to a battery that won't charge.
Old Oct 12, 2008 | 09:34 AM
sckirklan's Avatar
sckirklan
Anyone know if there's a year conversion list hidden in a forum topic around here somewhere or is it mostly just ask for someone who's dealt with it before to jump in?
Seems like a nifty thing to have anyhow /shrug.
Thanks!
Old Oct 12, 2008 | 10:44 AM
dan91ford150's Avatar
dan91ford150
It might work.
If you were to leave the 2 important items in place, like the speedometer so the computer would get signals (under the dash somewhere) and something in place so it could charge.
Then your next issue would be finding the proper inputs for the newer gauges, and of course seeing if they will fit there...
Old Oct 12, 2008 | 10:53 AM
subford's Avatar
subford
The charge part is just a pin wire change. Changing to the wrong year cluster can block (open the wire) from the Ignition Switch through the charge bulb with its burn out resister in to the wire going to the charge off/on point of the alternator.
Old Oct 12, 2008 | 07:45 PM
todd515's Avatar
todd515
Thanks, I think i will leave well enough alone
Old Oct 13, 2008 | 07:00 AM
jarod17's Avatar
jarod17
I doubt that big of a year jump will work. My cousins looks a lot different than mine.
I did have a cluster from a '93 in my '96 with no problems to test it out before I sell it. I now have a '97 cluster in my truck.
Old Oct 13, 2008 | 07:23 AM
Moore558's Avatar
Moore558
If you DO want something different for a cluster you can try what Frederic did awhile back.
https://www.ford-trucks.com/forums/6...r-upgrade.html
