Progress on 46 1/2 Ton
Old 07-06-2016, 10:24 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
You might want to pull the t-stats, disconnect the hoses and fan belt, then run and look for bubbles inside the thermostat housings. Something isn't right if it runs 180 without the 180 T-stats and heats with them in, maybe an internal crack or leaking head gasket.
  #137
Old 07-07-2016, 07:55 AM
Joe777's Avatar
Joe777
Joe777 is offline
Maybe start with testing the T-stats in a pot of water to see if and at what temp they are opening up???
  #138
Old 07-07-2016, 09:07 AM
46fordgal's Avatar
46fordgal
46fordgal is offline
Yeah, I am fairly certain it's a t-stat issue. I am going to run it without them for the summer and revisit installing them in the fall. I am done with antifreeze clean-up and gasket scraping for the time being.
  #139
Old 07-07-2016, 06:50 PM
tobolamr's Avatar
tobolamr
tobolamr is offline
Beautiful job on this truck. Very inspiring!
  #140
Old 07-07-2016, 07:45 PM
white 66's Avatar
white 66
white 66 is offline
Brake light switch
Originally Posted by 46fordgal
I am starting to think my truck is cursed. It's been one issue, after another, after another... Generator was squeaking so I brought it in for repair. Then I was having overheating issues with the 52 flathead. I would drive it a couple miles and it would be at 230-240. I replaced the thermostats (180s) and it still overheated; I put in a new 3-core aluminum radiator, 6-blade fan, shroud, fan spacer, new Speedway water pumps and it still was too hot (220). I took out the thermostats and it runs at 180 now. Don't know how it will be for longer distances, but for now it is good and it runs much better. When I pulled it in from my successful test drive, the brake lights were stuck on. I just ordered a new stop light switch. I can't imagine what will prevent me from driving it next; I don't think it's destined for the open road!
I have had difficulties with the re-pop switches, I keep on in the glove box just in case. Also I have had the lights stick on when the brakes were to hot one time, being new there was little room for expansion to the drums. I was using DOT 5 brake fluid which does not handle heat as well as the others. Changed that out and the problem was solved.
M
  #141
Old 08-15-2016, 10:31 AM
46fordgal's Avatar
46fordgal
Sweet Success
I drove the truck to a car show for the first time yesterday. It was about 20 miles away from home on a sunny 85 degree day. Absolutely no issues on the way there or home! I won a trophy! I need to find a shut off valve to put on the block for the heater. It would have been a much more enjoyable drive without the heat in the cab from the heater.
  #142
Old 08-15-2016, 09:43 PM
Joe777's Avatar
Joe777
Joe777 is offline
Congratulations! You must have been sweating bullets with that heater circulating.
  #143
Old 08-15-2016, 10:07 PM
newold46's Avatar
newold46
newold46 is online now
Here and congrats on the trophy, you deserve it!
  #144
Old 08-16-2016, 01:17 AM
Captain Sygo's Avatar
Captain Sygo
Captain Sygo is offline
I'm feeling the same pain about having a seemingly cursed truck. I keep telling myself that if it was easy, I wouldn't be learning anything. You've done an amazing job with yours - WOW!
Captain Sygo
  #145
Old 08-16-2016, 11:32 AM
46fordgal's Avatar
46fordgal
Thanks for the link! I am ordering it today. Looks like I will be draining the radiator once again. Wish I would have thought about getting the shut off a month ago. Hindsight is 20/20.
  #146
Old 08-16-2016, 11:50 AM
newold46's Avatar
newold46
You're welcome and yes, I have to do the same thing.
Jkraft46
1947 and Older Ford Trucks
07-23-2019 07:30 PM
allplotts
29
06-07-2013 09:06 PM
schoo
07-15-2012 11:30 AM
e-tek
02-05-2012 06:45 PM
e-tek
05-21-2010 07:23 PM
Quick Reply: Progress on 46 1/2 Ton
