Aerostar Ford Aerostar
Computer codes??? Rough idle???
Old Jul 12, 2003 | 01:54 AM
Wizard-of-Aaahhs's Avatar
Wizard-of-Aaahhs
Question Computer codes??? Rough idle???
I have a '90 Aerostar with a 3.0, is there a way to retrieve computer codes with the ignition switch?--- ALSO--- It runs well but idles rough, any ideas on this? I changed the plugs but it still does it.
Old Jul 16, 2003 | 05:49 PM
Mikeman's Avatar
Mikeman
You should also change the wires, cap and rotor and, while you're at it, the PCV valve and air cleaner, if they haven't been done for a while. Clean the MAF sensor. There are other possibilities, but no use going there until these items are taken care of.
There is a way to retrieve codes by putting a jumper on the test connector and counting the number of times the check engine light blinks. But, if the light isn't on, you won't get any codes.
Old Jul 25, 2003 | 10:36 AM
oldmantwinter's Avatar
oldmantwinter
Mine is doing the same thing......94 4.0l
What did you find out?????
Old Jul 25, 2003 | 10:47 AM
agelder's Avatar
agelder
Do yourself a favor before anything else, pull off the back engine cover (the one that goes into the passenger compartment) and check the vacuum tree. I have been having idle problems for a while, and I thought my brake booster had gone. On a hunch, I followed the vacuum line back to the rear of the engine and found it loose. I pulled the cover and found 4 vacuum fittings without their mates!!! I started plugging lines back in, and I got my brake booster back, my air conditioning had only been blowing out the defroster and now functions properly, and my idle has gone from rough nearly dying to slightly rough, but there is still one fitting open that I plan to cap. Got quite a bit of power back too.
Harry Thompson
1997 - 2003 F150
Aug 28, 2009 07:48 AM
fmrplt
1983 - 2012 Ranger & B-Series
Mar 2, 2008 09:48 AM
DKdude
Dec 18, 2007 05:21 PM
wjtownsend
Aerostar
Feb 8, 2007 07:02 PM
OldSHO
Mar 10, 2006 02:38 PM
