Sponsored by: Auxito
4.2 runs rough
Old Aug 13, 2009 | 08:56 PM
Harry Thompson's Avatar
Harry Thompson
Unhappy 4.2 runs rough
I have a 1998 F150 with the 4.2 V6. I just replaced all four O2 sensors and several others that were showing codes on the diag-computer. The check engine light was on before the replaced parts and is still on? For a couple of weeks after the sensor replacement it idled fine. But now it idles rough and this rough idle is intermittent from rough to almost stall. It is a bother but has not stalled yet. Seems to be worse when the engine is hot. Generally I take good care and the engine is in good condition. Also no codes show on the computer? I suspect the idle control or MAS, but this is a guess? Please help.
Old Aug 13, 2009 | 09:03 PM
Ultramagdan's Avatar
Ultramagdan
Sounds like your IAC is acting up.
Old Aug 28, 2009 | 04:14 AM
oneeyedmac's Avatar
oneeyedmac
Please forgive my ignorance, but what is an IAC?
Old Aug 28, 2009 | 06:16 AM
torkum's Avatar
torkum
Idle Air Controller= maintains air coming in to the engine when the throttlebody is closed.
Old Aug 28, 2009 | 07:01 AM
oneeyedmac's Avatar
oneeyedmac
thanks, much appreciated.
Old Aug 28, 2009 | 07:48 AM
bokker's Avatar
bokker
hi, check the rubber boot under the manifold in the middle. it perishes coursing a vacuum leak and many of the problems you describe. good luck bokker.
stevekantercool
Feb 18, 2017 03:47 AM
zephyrprime
Jan 20, 2017 05:57 PM
76vetteluv
Modular V8 (4.6L, 5.4L)
Jan 8, 2017 11:34 AM
zephyrprime
Dec 21, 2016 11:20 AM
Oversized Chuck
Jul 27, 2016 01:08 AM
