89 Ranger computer
Old Mar 1, 2008 | 09:42 AM
fmrplt's Avatar
fmrplt
89 Ranger computer
I'm still working a problem with the engine's rough idle, but everytime I hook up the scanner to try and read codes it comes back as computer not responding. Could this be a computer problem? Wires are in good shape and when starting the scanning process it gives me everything to do. Should I replace the computer and test it again? Could this clear up my other problems with the engine? Thanks.
Old Mar 1, 2008 | 09:55 AM
mblatz's Avatar
mblatz
is you engine running when you are trying to pull the codes?
Old Mar 1, 2008 | 10:24 AM
fmrplt's Avatar
fmrplt
Yes, that's one of the steps it tells me to do.
Old Mar 2, 2008 | 12:23 AM
mblatz's Avatar
mblatz
ok. the engine should NOT be running during the test. what you are supposed to do is warm up the engine to normal operating temp, then shut the engine off. after that you turn the ignition to on but DO NOT START. then try testing. i made the same mistake a few times too before figuring it out myself... it happens to everyone. give that a try and let us know!
Old Mar 2, 2008 | 09:48 AM
fmrplt's Avatar
fmrplt
Okay, I'll do that today - thanks.
scoobydum
Computer Chips & Tuners
Jun 10, 2012 07:59 AM
bliss1
Sep 13, 2008 10:01 AM
bigpowerstroke
Nov 12, 2007 10:51 PM
dbthumper1
Bronco II
Sep 11, 2003 12:02 PM
Georgem
May 29, 2002 09:17 PM
