Sponsored by: Real Truck
6ft bed weight??
Old Aug 13, 2014 | 10:30 AM
ultrasks700's Avatar
ultrasks700
6ft bed weight??
My 2004 F350 has a decent amount of surface rust(underneath) from 10 years on new england winters, no root yet or anything serious yet so I plan on making a "jig" in the garage, removing the bed, and taking care of all the surface rust. Just wondering what you guys think a bed weighs in at? i started removing those Torx head bolts, 6 are free, only broke 4 bits doing so...
Old Aug 13, 2014 | 11:34 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I lifted mine with three people, one of them a retired woman. Three guys can do it fine, two would be hard to balance the bed (that's where the lady came in to play, balancing but not lifting). You could always slide a pair of 2x4s under and put it up on sawhorses and drive the truck out from under, that way you don't have to lift the bed back off the ground.
Old Aug 13, 2014 | 12:07 PM
David7.3's Avatar
David7.3
PB Blaster, soak them over night, save yourself some torx bits. Thats the only penatrating sprat we use in the shop, nothing better.
Old Aug 13, 2014 | 07:15 PM
kd0axs's Avatar
kd0axs
PB Blaster is good, but nothing beats Kroil.
Sent from my HTC ONE using IB AutoGroup
Old Aug 14, 2014 | 02:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the bed is rusty enough to have to change it, you will most likely be cutting the heads off the bolts and replacing them.
i only got 1 of the 6 off when i changed the bed on my 02.
Old Aug 14, 2014 | 05:47 AM
ultrasks700
I am not changing the bed, just cleaning up some of the rust underneat and on the frame, I'm kinda **** about that stuff, the truck has zero body rust, which is great for a ten year old new england vehicle.
Anyways, my plan is to pull the truck in the garage, hook four come alongs to the ceiling, unbolt the bed and drive the truck out and do what i need to do. have 6 bolts free now, the other two are going to get battled tonight, PB blaster has been applied. keep you guys updated.
OldWoodsDiesel
Sep 15, 2014 07:09 AM
f100jim
Aug 11, 2010 02:36 PM
swaybar
Mar 6, 2008 11:17 PM
BigJim191
Mar 20, 2007 07:17 AM
Villagemonkey
Nov 6, 2004 12:52 PM
