Overheating issues
Old Aug 13, 2014 | 08:49 AM
jdeanjunior's Avatar
jdeanjunior
Overheating issues
I am working on my '78 f150 4x4. It has a 300 6 cylinder engine.
After all the long hours of getting this truck done I finally get it out on the road and it overheats. I have replaced everything in the cooling system. Some buddies said that the thermostat could be sticking so I replaced it same problem, the I took it out and ran it still overheats. I am turning to you guys for advice on what could be causing this truck to overheat outside of the cooling system? I can drive this truck for about 20 minutes at speed and then heat gauge just starts going up. any advice you may have is appreciated.
Old Aug 13, 2014 | 08:56 AM
74F100LGM's Avatar
74F100LGM
How's the timing?
Old Aug 13, 2014 | 09:10 AM
jdeanjunior
Had the timing checked while I was getting the suspension done. Mechanic said He was looking at some old books to find what the timing was. He told me he set it at 10 BTDC. I did not verify it but I will now
Old Aug 13, 2014 | 10:08 AM
460 FORD MAN's Avatar
460 FORD MAN
If you are going off the 'dummy gauge' get a cheap aftermarket gauge and see what the temperature actually is.
Did you 'burp' it to make sure you got all the air out of the block?
azoutlaw
Jun 19, 2015 02:28 PM
DKW 86
Dec 8, 2010 03:34 AM
lbrauer
Jun 2, 2010 09:07 PM
kermmydog
Sep 24, 2006 03:01 PM
LimeyZ
18
Jul 27, 2005 06:16 PM
