CDR Source?
Old Aug 12, 2014 | 09:59 PM
Macs1964F100's Avatar
Macs1964F100
CDR Source?
Where is a the best place to get a CDR? I took mine off and did a blow test and all was good. I soaked it in gas for an hour, gently agitating it and it no longer works. Very black oil drained from the weep hole. After 2 hours of draining I could not get to to function properly.
It is a 94 NA with 240k and the engine is using a quart of oil every 150-200 miles. I do not see blow by when the oil cap is off. With this much oil consumption I would like to have the "engine run away" protection the CDR is providing.
Is there a baffle available to precipitate some of the oil from the crank case gases and drain it back to the sump? $4 diesel is bad enough, $16 oil is too expensive for fuel. There are no visible oil leaks and the engine runs fine. Are there other places it could be loosing oil?
Old Aug 12, 2014 | 10:32 PM
oldblue89's Avatar
oldblue89
Ford dealers should still be able to get it, that's where I got mine, I believe I paid around $59 for it though (as of 4 months ago)
Old Aug 13, 2014 | 12:11 AM
Macrobb's Avatar
Macrobb
The CDR isn't going to really stop gasses; it just prevents sucking a little.
Considering you're NA, there isn't much in the way of vacuum, so it really doesn't do a whole lot, and the gasses won't run the engine enough to make any difference -- it takes a turbo seal failing and pouring oil down the intake to get a runaway situation.
You can come up with an oil/air separator if you want; I made one out of a piece of 6"x4" ABS pipe filled with fiber filter material; let the oil drain out of the bottom into a bottle(with a drain hose) and then I empty that bottle when it gets full.
It's captured a lot, but it's a lot easier to make that setup when you've a turbo... and it means a lot more.
I'm thinking you may need to run that engine hot a few times; apparently that can help oil consumption as the carbon gets cleaned off the cyl walls.
Old Aug 17, 2014 | 08:05 PM
airdale94's Avatar
airdale94
fordpartsgiant.com is a good source.
Old Aug 18, 2014 | 01:43 AM
genscripter's Avatar
genscripter
I just bought mine 6 weeks ago, and the cheapest I could find was on Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com . Probably cheaper elsewhere, but I couldn't figure it out. They delivered it to the dealer so I didn't have to pay for shipping.
$79 bucks. Search for
<table><tbody><tr><td>E3TZ6A665A</td><td colspan="2">
</td></tr></tbody></table>
robbie7045
May 1, 2015 09:45 PM
CheaperJeeper
29
Aug 10, 2007 08:18 PM
leatherbee
Jan 25, 2007 09:08 PM
tempfords
16
Dec 1, 2006 09:18 PM
kev100
Oil & Lubrication
Sep 22, 2005 10:14 PM
