1973 F100 - Grumpy
#152
Loss of oil pressure and an oil leak ... could be a head gasket.
As for the '69 vs '73, not sure when they put the hardened valve seats in to be safe with unleaded gas - was that '73 or '74? May need to use an additive in your fuel with the older model if it hasn't been overhauled. Also not sure when they dropped the compression ratio from ~9.5 to 8.4? 69 could be better from that perspective...
#153
#154
#155
It's a useful rule of thumb, and true in that direction just not necessarily the other. By 1974, every engine was coming with hardened seats to run unleaded gas, whether it needed cats yet or not, according to my owner's manual. That started sometime in the early 70s I think, but I don't know precisely when.
#156
#157
#158
$2500? Heck, I bought one of these (reman) for $1000 shipped when building mine, and it is made with quality components (Sealed Power, Clevite, etc.): Mustang 5.0L 302 Economy Short Block Accepts Roller Cam (79-95)
For around $2k, they sell a reman short block with forged pistons, etc. for race applications...
Those are just short blocks w/o a cam though, no heads.
But I think what they quoted him was completely rebuilding his 302 ... 2500 is probably about right there, *if* it includes all the labor & machining. By the time heads, gaskets, add'l labor, etc. are included, that's about what you'd end up with if the short block is around 1k.
#159
#161
Dont be to shy about checking out a 5.8 windsor. They'll take a 2 bbl and the extra torque and ponies will make your truck a good runner. The newer efi blocks last a long time and you can get some $ back on the intake as the bottom half is a cobra unit as long as it comes from an exploder or 1 ton. Rumour has it that the 94 and newer have roller lifters same as the 5 liters. Google your motor options, wikipedia has some good spec and historical information.
#162
#164
#165
Well I suck at updates lately. Not much to update but I found a donor. '70 302 out of a bumpside. Drove 500km 325miles to find it. only to find its originally from my town lol... oy vey..
Then a princess auto pig iron engine stand. things so cheaply made that one wheel wont go on.. so trusting eh?!
