AE GEM Central Timer?
Old Aug 10, 2014 | 09:38 AM
Walleye Hunter's Avatar
Walleye Hunter
I am getting a GEM Central Timer no response message from my AE diagnosis on my e99 F-250. This is new from the last time I ran the test. What does it mean?
Thanks,
Mark
Old Aug 11, 2014 | 12:36 AM
retiredsparky's Avatar
retiredsparky
That sounds like one for the "AE specialists" should they decide to accept this mission.
Old Aug 11, 2014 | 06:34 AM
Tugly's Avatar
Tugly
I've hooked up to the GEM on Stinky without issue, so I have to ask what symptoms are you dealing with that made you try to hook up?
Old Aug 11, 2014 | 06:40 PM
Walleye Hunter
I am having slipping issues with a newly rebuilt tranny so I hooked it up. That message came up and it wasn't there before. Otherwise I don't have any new issues that I know of (there are the ABS and airbag, which I already know about).
Thanks,
Mark
Old Aug 12, 2014 | 07:01 AM
Tugly's Avatar
Tugly
Ah.... If I'm remembering correctly, it should have that same message for a number of modules. When you first connect, the system gives you the option to read all codes, so it polls everything it's connected to. Well... if you connect to the Enhanced Powertrain, then you will receive info from only so many modules. ABS is one of those modules you have to directly connect to, as is the GEM and the Overhead.
B846B
May 27, 2021 01:29 AM
Longshot
1997 - 2003 F150
Sep 14, 2016 07:08 PM
85F350IDI
Mar 3, 2016 04:27 PM
catfish4
1997 - 2003 F150
Aug 22, 2011 12:20 PM
