Need mechanic in Maryland
Have you pulled the inspection cover and had a look up in there yet? There is also a high pressure oil rail plug on each end of each head that can leak. The plugs have a 1/2" square drive hole in them. It might be worth having a look at with an inspection mirror. It's the large one near the top in this picture:
Inspection mirror would help, my bet is on turbo pedestal o-rings, as stated, rear mains are very uncommon. The valley is kind of split into 2 spots really due to a rise, but there can be leaks in the front of the valley and the rear, either from turbo, rear oil plugs, or if the front hpop lines/fittings, or plugs.
The inspection cover is the "dust" cover between the motor and transmission, underneath remove it to see the flexplate/flywheel and see if the oil is leaking from behind it since that's where the rear main is.
x2 on whAt Big Al said. I've experienced the same thing you're describing, before I reall got to know my truck. Pulled my engine out to replace the rear main seal only to find it was a turbo pedestal o-ring. Mine looked like a garden hose was spewing oil out of the rear main seal. Look at it this way- even if you have to pull the engine, turbo has to come off anyway. Why not start with it and see what you find?
1988 f 350 ford
05-17-2007 02:10 PM
rutang
21
01-17-2007 08:33 PM
