speedometer off
Old Aug 8, 2014 | 06:18 PM
brokeasajoke's Avatar
brokeasajoke
speedometer off
So using my gps my speedo reads ~5mph fast. Mine is driven off of tcase. Dont remember gear color or teeth count. 235s 4:10 zf5. Can i change just gear on cable end or do i have to change worm drive gear?
Old Aug 8, 2014 | 10:00 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Seems about par for the course on OBS trucks. My 92 is fast and so is our 97.
Old Aug 8, 2014 | 11:21 PM
Red454sedgwick's Avatar
Red454sedgwick
I put bigger tires on and it was right. I don't think you have to change the worm gear I did a 4.10 and 3.55 a couple years ago and they had the same worm gear it's either brown or yellow the gears are color coded
Old Aug 8, 2014 | 11:23 PM
Red454sedgwick
with the digital speedo there is suppose to be an dial on the back of the instrument cluster, but I've never cared enough to look.
Old Aug 9, 2014 | 04:01 AM
tjc transport's Avatar
tjc transport
i ain't rite
yup, all you need to change is the cable gear . i have used red,yellow, green and white gears in my 88. 1 tooth is good for about a 2.5 mph change in speedo reading.
Old Aug 10, 2014 | 06:12 PM
speedwrench72's Avatar
speedwrench72
I believe on digital dash you have to flash the PSOM. on trans with vss in the trans 92 and earlier you just change gear, there are two output shaft worm gear ratios, should be ok.
Old Aug 10, 2014 | 06:25 PM
tjc transport
i ain't rite
pre 91 is simply changing the gear on the cable, 92 and newer is electronic and reads off the VSS in the rear differential.
Old Aug 10, 2014 | 07:00 PM
speedwrench72
the cable and gear are for the speedometer and odometer, the vss converts information to electrical signals for the E4OD PCM, ALL VEHICALS with E4OD have a vss on tranny or when they went digital used the same sensor for anti lock, speedometer, cruse control, and tranny in latter models mounted in rear-end. not all vehicles, or drivetrain combinations that ford produced went digital at the same time.
Old Aug 11, 2014 | 12:12 AM
BruteFord's Avatar
BruteFord
Originally Posted by brokeasajoke
.... my speedo reads ~5mph fast.....
Originally Posted by tjc transport
...... 1 tooth is good for about a 2.5 mph change in speedo reading.
Cause speedo calibration is a math thing I need to point out that these statements don't give enough information. Speedo correction is a matter of percentages or ratios, so "5 mph fast" or "2.5 mph change" also need to know at what speed so a percentage or ratio can be found. For example if it's reading 5 mph fast when you're going 50, then it's 5/50 or 10% off, but if it's reading 5 mph fast when you're going 25 then it's 5/25 or 20% off.
Old Aug 11, 2014 | 05:01 AM
tjc transport
i ain't rite
once again.
SPEEDOMETER on vehicles 91 and older is gear driven.
SPEEDOMETER on vehicles 92 and newer is electronic and driven off the VSS is the rear differential.
we are not talking about ABS, trans signal, or cruise control signal.
if you disconnect the electrical sensor on a pre 91 vehicle with E4OD trans, the speedometer will still work, but the trans will go into limp home mode.
Old Aug 11, 2014 | 04:09 PM
brokeasajoke
Cant really tell under 25 too much bounce. But seems 5 off everywhere respectively per gps +or- 1 mph to 55- 60 mph. Mine is an 88.
Old Aug 11, 2014 | 05:02 PM
tjc transport
i ain't rite
if you are off around 5 mph low at 55-60, i would drop 2 teeth size on the speedometer gear. this should get you in the ballpark.
this is what i had to do to get mine close.
Old Aug 11, 2014 | 06:10 PM
brokeasajoke
Im reading 5 fast so i should go up 2 teeth correct? Which should turn cable slower.
Old Aug 12, 2014 | 04:55 PM
tjc transport
i ain't rite
correct...
Aaron Keiser
Sep 30, 2018 10:28 PM
Hunt89
20
Apr 16, 2010 04:12 PM
cbfomoco
Sep 23, 2008 03:10 PM
MikeGV
Sep 26, 2005 09:30 PM
nate5812
Apr 15, 2005 04:02 PM
