Hello
Old Aug 7, 2014 | 08:54 PM
BeardedForLife's Avatar
BeardedForLife
Hello
Hello all FTE members. im new to this forum. I have a 52 Ford F3, that i'm currently trying to place a 1975 lincoln 460 BBf with a C6 trans in to looking for any insight and tips on how to accomplish this. thanks for letting me be apart of this site.
Old Aug 8, 2014 | 05:22 AM
FortyNiner's Avatar
FortyNiner
Welcome to FTE! If you haven't already done a search (Google will work for now)- should help find existing threads on your topic. Any pics to share?
Old Aug 8, 2014 | 05:45 AM
Harrier's Avatar
Harrier
Welcome to FTE!
I can't help with answering your question, but I would love to see pictures of your truck.
What are your plans for her?
Old Aug 8, 2014 | 07:36 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
First off welcome!
Request a Classic Haulers catalog. Catalog Request - Classic Haulers F-1 Parts 1-877-252-1948
Here's what you'll need.
1952-64 Ford F-100 Crossmember Engine Mount, Ford 429-460 Big Block & rubber mount
1948-79 Ford F-100 Shift Linkage Ford C6 Transmission To 2" Column or something similar for your column
https://www.performanceonline.com/19...EMBER-TCM4860/ & rubber mount
Aftermarket Transmission cooler, steel and rubber cooling lines.
Hopefully you have; Transmission Yoke, Neutral Safety/Backup light Switch & carb to transmission kick down linkage with the transmission. Gonna need a new drive shaft built (or old one cut down) too.
You may need a longer speedo cable but try to use your exsisting speedo cable first. You'll need to change the gear on the transmission end of the cable for your rear end ratio & tire combo
Good luck and keep us posted on your progress.
coves
Aug 16, 2017 05:21 PM
59 shorty
Jun 24, 2013 01:07 AM
TBTRUCK
Sep 30, 2012 12:55 PM
BigBlueCat
Aug 26, 2011 01:57 PM
rw84f150
Nov 30, 2004 08:35 PM
