Speedometer Cable Help
Old Aug 14, 2017 | 04:52 PM
coves's Avatar
coves
Hi, brand new to this site and looking to see if anyone has insight to an issue with finding a cable that will fit a 1989 Crown Vic automatic 4-speed transmission to a 'threaded' speedometer for a 1949 Ford F1 truck speedometer (see pics).
I can buy the original cable for the 1989 crown vic, but the speedometer end will not work with this cable... maybe some sort of converter or need to find a cable that will work, with the proper ends. Searching around eBay, just wondering is someone has a link that may be better than guessing.
Best Regards and thanks so much for responding if you can help.
Bill
1949 Ford F1
Old Aug 14, 2017 | 09:18 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to here....hope you can get some help........that we may be able to do
Old Aug 14, 2017 | 09:47 PM
abe's Avatar
abe
Bill, welcome to FTE the best Ford Truck Forum on the World wide Web!
I can't answer your question but someone will be here soon that can. But first you must tell us about you truck and show us a few pictures!
fordbuddy79's Avatar
fordbuddy79
This is who I used.
Speedometer Service of Milw providing speedometer solutions
He is very reasonable,Hope it helps.
John
Old Aug 15, 2017 | 10:13 AM
yamagrant's Avatar
yamagrant
I'm running an 88 5.0 / AOD, and bought a cable from Midfifty's. I haven't installed it yet, but looks like it will work fine. Good luck
Old Aug 15, 2017 | 09:25 PM
682bear's Avatar
682bear
On my '51 with an AOD, I used a cable from a '64 Fairlane... both ends fit correctly...
-Bear
Old Aug 15, 2017 | 10:18 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Welcome to FTE
Watching this post for answers.
Old Aug 15, 2017 | 10:39 PM
682bear's Avatar
682bear
If the '48-'50 speedometers have the same size cable connection as the '51, the '64 Fairlane cable will work. My AOD is out of an '89 T-bird, so it should be identical to the '89 CV transmission...
And, the cables are around $25 at Autozone...
-Bear
Old Aug 16, 2017 | 12:55 AM
matthewq4b's Avatar
matthewq4b
Bill
1949 Ford F1
Is there any reason you are keeping the VSS in the AOD ? Cruise or EFI ?
If not pull the VSS and use the original speedo cable with the AOD speedo gear and it should work.
Old Aug 16, 2017 | 05:19 PM
coves's Avatar
coves
Thanks so much for the quick replies, I'll get the hang of this site yet as I have more questions once I sort out finding the right cable which I am sure I can now. Just been very busy at this time.. need to slow down and get back to my project.
I have attached some pics of my project F1, it has a rebuilt 1089 5l, from a crown vic, with ps, pb (front disks & coils), rear end is a solid 9" from a 65 Galaxy.
Thanks again!
Old Aug 16, 2017 | 05:21 PM
bjmayberry2
Lookin Good
91Fbody
Feb 28, 2016 07:31 AM
easyrider47
21
Aug 24, 2014 09:03 AM
coopdagook
Jul 31, 2011 05:33 PM
jeffz
May 5, 2011 11:25 AM
jml
Aug 8, 2002 07:50 PM
