idle sensor
Old Jul 11, 2003 | 05:06 PM
cbeaur's Avatar
cbeaur
idle sensor
My 89' F350 stalls 9 out of 10 times when I go from forward then to reverse and vice versa. Could this be from the idle sensor, Im running out of ideas with this.
Old Jul 11, 2003 | 07:50 PM
ExcellentRed's Avatar
ExcellentRed
idle sensor
My pickup has the same problem. I have replaced the IAC, spark plugs, wires, cap, rotor, and had the ignition timing fixed. But alas, no change. I posted this problem here before and some ideas were that some sensors in the transmission were causing the motor to not get enough fuel or the torque comverter was grabbing too soon. I think the main computer may be the problem with my truck. I hope we get some replies so we can figure out what the heck is wrong.
Old Jul 11, 2003 | 08:27 PM
Phillip Guidry's Avatar
Phillip Guidry
idle sensor
First off, clean the throttle body bores and flaps and the pintle valve for the Air Bypass...this will definently improve idle quality between engine load changes.
Phil
Old Jul 11, 2003 | 09:19 PM
c_rossman's Avatar
c_rossman
idle sensor
Check those brittle vacume lines that go to the EGR and Smog systhems. I would run new lines anyways. I am positive you will find a crack somewhere. Throttle body gaskets like to get sucked out too. they are less than 2 bucks and worth replacing when cleaning the throttle body.
Old Jul 12, 2003 | 12:27 PM
steve83's Avatar
steve83
idle sensor
Have you pulled the codes? (<-That's the link)
ATC Crazy
1997 - 2003 F150
Mar 7, 2007 08:03 PM
turbozeke418
Nov 11, 2005 08:28 AM
cavitill
Apr 16, 2005 12:20 AM
Fordtruc526
Jan 18, 2005 11:17 AM
slater8
1983 - 2012 Ranger & B-Series
Jul 10, 2003 12:09 AM
