Idle Sensor Humming Sound
Old Jul 9, 2003 | 05:46 PM
slater8's Avatar
slater8
Question Idle Sensor Humming Sound
Hi,
I have a 97 Ford Ranger 4.0 XLT. The engine runs fine, but the idle sensor makes a loud humming noise when the engine has been running for a while. If I get back out on the highway and drive for a while the sound goes away, but as soon as I start to do some more around town driving the sound comes back.
Is that humming sound normal?
Does the black plastic knobbie thing on the idle sensor (where the noise is coming from) need lubricating or something?
I also wonder if it is the MAP sensor which is on the intake in line just prior to the idle sensor. The manual says that the map sensor is designed to run at a low tempeture, so I'm wondering if the warmer temps of around town driving is causing the map sensor to malfunction (?)
I'd really appreciate a clue. Otherwise I love my 2 tone XLT.
Old Jul 9, 2003 | 06:09 PM
alancp's Avatar
alancp
if u unplug the wire going to it while it is idleing and making the humm noise it will go away if it is this part. I have replaced mine and cant see that the black **** does anything. there is a possibility that u can clean the valve assembly inside. i kept my old one and cleaned it but have not tried it. the part is around $60.oo . later alan
Old Jul 9, 2003 | 06:33 PM
Rockledge's Avatar
Rockledge
Hi slater8, welcome to FTE!
You should probably read through these recent threads:
Ranger IAC Noise1
Ranger IAC Noise2
Old Jul 10, 2003 | 12:09 AM
slater8's Avatar
slater8
Thanks Alancp for the tip. Based on your post and some others I will try cleaning the idle sensor and if that doesn't work I'll just replace it.
Bowhunter916
Jan 18, 2025 09:21 PM
Broskiie
Dec 10, 2024 07:52 PM
jzu22
Jul 23, 2021 07:22 PM
cjben
Jul 15, 2016 12:33 PM
emiexco
Mar 31, 2016 04:05 PM
