Sponsored by: Auxito
High Idle
Old Mar 6, 2007 | 01:37 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
High Idle
I did a search and found nothing. Only topics discussing rough idle or erratic/low idle.
My truck ('97 4.6L auto. 97K miles, all stock) just started this yesterday. Normal idle RPM is about 750 whether in gear or not. Now, it's idling at about 1050 in neutral or park and around 975-1000 in gear. I noticed sitting at a red light, when I had to use more brake pressure than normal to keep the truck from rolling. Thats when I looked at the tach and discovered that it was idling around 1K.
My mechanic friend seems to think it's the TPS...
Could I go around and unplug sensors one by one to see what it does until I find one that makes it return to normal Idle speed? It worked on my friends Dodge (wouldnt idle) and turned out to be his MAP sensor..
Anyways...what do you guys think it could be? Im not the best when it comes to all these sensors and electronics.
Old Mar 6, 2007 | 01:40 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Another question...
It wouldnt be due to an extremely, horrendously bad exhaust leak would it?
Old Mar 6, 2007 | 01:58 PM
KingRanchMan02's Avatar
KingRanchMan02
I would suspect a dirty IAC valve.
Old Mar 6, 2007 | 11:02 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thanks for the info. I guess I'll have to tear into it this weekend...
Old Mar 6, 2007 | 11:18 PM
rsylvstr's Avatar
rsylvstr
+1 ................
Old Mar 7, 2007 | 10:57 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If I would need to replace it, how much would they be from the dealer? Anyone had to buy one?
Old Mar 7, 2007 | 11:35 AM
Johnny Langton's Avatar
Johnny Langton
A good dealer will only charge you around $65 for it. List is nearly $100. It's not the TPS,it's either the IAC valve or possibly a vacuum leak allowing more air in around the TB.
JL
Old Mar 7, 2007 | 12:25 PM
xtrford's Avatar
xtrford
I have heard of PCV tubing connecting to the back of the throttlebody elbow tends to crack causing a vacuum leak. It will be right next to the IAC so an easy one to check.
Old Mar 7, 2007 | 04:17 PM
thehawk789's Avatar
thehawk789
yeah, it could either be a stuck iac, or the iac is opening up so your engine can compensate for some other problem like a vacuum leak.
Old Mar 7, 2007 | 08:03 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Well...thanks for the tips! I've got another major problem (for the wallet) that started today. I think the alternator is dead. Lost all power on the way home from work tonight....no gauges, could barely see the headlights/gauge cluster lights, and my stereo went dead...
Time to trade it in...
90pioneer
May 11, 2013 11:29 AM
EMC V10 X
Modular V10 (6.8l)
Dec 31, 2010 06:39 PM
mvvette97
Dec 1, 2008 10:51 AM
1BadF150
1997 - 2003 F150
17
Jan 12, 2005 10:35 PM
