Swapping Distributors?
Old Aug 5, 2014 | 06:24 PM
Ratty Truck's Avatar
Ratty Truck
Hi,
What, if any, distributors are interchangeable for a 292 Y Block? Maybe from a 289 Ford?
Old Aug 5, 2014 | 07:23 PM
Tedster9's Avatar
Tedster9
They look similar but are not iirc.
Sent from my iPhone using IB AutoGroup
Old Aug 6, 2014 | 03:48 PM
charliemccraney's Avatar
charliemccraney
They are not interchangeable with any other engine family.
'54 is different than '55-'56 which is different than '57-'64 and there will be subtle variations within those ranges. '57-'64 will work in a '54-'56 but it requires some changes to the way the distributor is used and/or that other components be swapped as well.
Functionally, the late Y-Block distributors are as good as a small block or FE distributor so swapping in that sense would not gain anything.
Stock distributors can be rebuilt and there are quite a few aftermarket options.
Old Aug 6, 2014 | 07:36 PM
Ratty Truck
Good to know. Thanks for the replies!
Old Aug 11, 2014 | 09:01 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
You want to look for a 57 up Y Block distributor. Some auto parts places still can get rebuilds. WHY? The 57 up has both mechanical and vacuum advances.
Also get a Pertronix electronic ignition and coil. Ignition Products
kd5fvm
Jun 25, 2019 12:19 AM
jamison29
Jul 7, 2018 09:06 AM
FordmanShane
Oct 28, 2013 03:52 PM
3414
Jan 28, 2010 09:28 AM
64bird
Feb 1, 2002 10:33 AM
